    Adjust imported image texture on a curved surface?
    3 Posts 3 Posters 285 Views 3 Watching
      CalypsoArt
      In my models I do a lot of quick and dirty painting with jpg images as textures. On flat surfaces I can right click and get texture position/sizing options. However not so on a curved surface. What is the best way to adjust textures on a curved surface?
        It depends how cirved it is - or what you need to achieve. You can wrap a texture around a curved surface but other than a cylinder (which only curves in one direction) this won't work. If your curve does not go completely around (or better: does not even reach 180 degrees) projecting the image is a good way to go (you can first position it on a flat face and sample the image from there).
        Then there are plugins you can use - and of course, the "toppest-nochest" one is SketchUV:
        http://sketchucation.com/forums/viewtopic.php?t=44501
        • panixiaP Offline
          panixia
          see also fredo trhu-paint.. excellent, easy to use, and free..
