    Make shapes in objects
    5 Posts 4 Posters 196 Views 4 Watching
      jasemilly
      everyone, I know how to make things like cups,vases, glasses etc.
      But say you want to make a fancy glass like a champagne flute and it has a pattern cut into the outside of the glass, how should you tackle that?
      thanks
      Jasemilly
        Aerilius
        And use Tools On Surface to fraw on the curved surface. Then use Joint Push Pull to extrude it in/out. You can also create another shape (extruded logo, 3D Text) move it into your flute and intersect it.
          Make a 3D glass with thickness
          Shape Bender by Chris Fullmer or Fredo Scale by fredo6for curvate a
          3D stright pattern then boolean difference substraction!
            jasemilly
            Am I right in thinking that these would be the steps.
            Create a rectangle that has a depth less than my flute,
            Create my pattern on this rectangle
            use the bend tool to turn this rectangle in to a cylinder,
            put the pattern over the glass then open up the glass oblect and intersect.
            Remove the patterned cylinder and tidy the original glass flute?
            thanks
            • pbacotP Offline
              You can also try sandbox drape, but only if your pattern does not wrap all around. You'd lay the glass on it's side. 2d pattern, drape then use joing push pull to recess.
              In most cases (whatever methods) you probably want to first scale the glass 100 times too large and scale down after the application of the pattern.
