    Load Error
    7 Posts 3 Posters 398 Views 3 Watching
      JBJDesigns
      Hi All,
      When I open Sketchup8, I get the following error message:
      [pre:1uyu2ih9]Error Loading File clipboard.rb
      uninitialized constant TTError Loading File core.rb
      uninitialized constant TTError Loading File loader.rb
      no such file to load -- TT_UV_Toolkit/core.rb[/pre:1uyu2ih9]
      Can you help me locate and fix the errors on these Plug-ins? OR Should I contact the author and ask for help?
      Thanks for your feedback!
      Jo πŸ˜„
      ...you send them to school, you give them books, and they eat the pages...
        Looks like an installation error. Check the way you've installed TT_UV_Toolkit.
          Either UV Toolkit is installed incorrectly, or you have Organizer installed - which messes up things by loading files in the sub-folders of SketchUp's Plugin folder.
            JBJDesigns
            Hi TT! Thanks for responding! You are correct... it was an install error on my part. I resolved the issue by deleting everything in my plug-in folder (sounds desperate... it was!). If you have a chance to reply, I need help on where to install the plug-ins. I read the help source (load Sketchup8 plug-ins to a folder created in the "my document/sketchup" directory -- which I did. But many of the plug-ins I downloaded are not being utilized by SU. My thought is the "older" plug-ins developed in previous versions of SU should be installed in the "program/scetchup8/plugin" directory. Your thoughts?
            By the way, I downloaded your plug-in and it works beautifully!!! The plug-in was dropped into the folder I created in the "my document/sketchup" directory.
            Anyway... thanks again for your help! Look forward to trying out your tea pot and cup, and having a spot of tea with you!!!
            Jo πŸ˜„
              Have a look at this article:
              http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
              Some plugins do assume they are located in Plugins folder - but not all. There's no way of knowing until you try really.
              And remember that some plugins might need to be enabled under the Extension list (under Preferences).
                JBJDesigns
                Hi TT! I downloaded the plug-ins and separated the ".rb" from the ".rbz"; the ".rb" was placed in the program directory for sketchup, and the ".rbz" was placed in the document directory for sketchup. So far, everything seems to be working fine ... I now have a truck load of plug-ins. Now the fun begins ... learning to use them properly! 😲
                Thanks again for your help. Jo πŸ˜„
                  πŸ‘
