    How do you resize a bounding box?
    3 Posts 2 Posters 399 Views 2 Watching
    • V
      val5214
      I have read a post under a similar title but it does not offer a solution to wanting to just resize the bounding box around groups/components alone. It mentions making a group a component or changing the axis' position but none of these work. Also rescale definition does not work. All I am wanting to do is tighten the box around the object. There is too much space in the bottom of the bounding box.
      thanks
      • BoxB
        If it is obviously too big, not in proportion to the other sides of the box, then you probably have a small bit of geometry hiding down there, open the box for editing and try selecting down there and deleting any odd bits.
        If it's just the normal bounding box then I don't believe you can resize it.
        • V
          val5214
          Thanks "Box" I went in and looked but did not find anything. however there was a group of guides that i had that had a ridiculously large bounding box around them nested withing the group I was in. i just moved the group of guides, then started a new group of the objects i was resizing -- now the bounding box is where it should be
          thanks!!!
