    Working with terrain (triangles)
    19 Posts 5 Posters 1.0k Views 5 Watching
    • P
      peebo22
      Hello!
      I need some advice with working with terrain.
      So, I have this triangulated terrain and I want to bring the roads to it, but how can I do it properly? The data is from Trimble Tekla GIS.
      It works with flat ground, but not with this.
      I usually bring separate dwg/dxf and I try to make surface from edges and drape them to the terrain.
      What is the proper way?
      Here is a picture of the work and I've put an arrow which shows the road on the terrain.
      http://i47.tinypic.com/30x956s.jpg
        here a PDF tutorial about that by Daredevil
        (sorry in French but with images and you can put the text in the Google translator πŸ˜‰
        • sdmitchS
          sdmitch
          The Drape Tool will place the outline of the roads on top of the surface but unfortunately as a series of unconnected segments. The Stamp Tool will maintain the road outline while connecting it to the surface and allow you to push it into or pull it above surface creating cuts and fills.
          http://sdmitch.blogspot.com/
          • KrisidiousK
            Krisidious
            I use instant road... it's awesome.
            404 Not Found
            (www.valiarchitects.com)
            By: Kristoff Rand
            • P
              peebo22
              Thanks, but it says that I'm not authorized to download this file...?
              Yeah, I have the instant road plugin, but I don't know how to use it with this. Any advices?
              • KrisidiousK
                Krisidious
                it's real simple.
                draw the road you want on a flat plane.
                make those lines a group.
                cut the group via cut/copy/paste
                open the land geometry and select everything (triple click)
                then go to the soften edges menu. check-mark soften coplanar.
                paste the road path above the land anywhere.
                select the road path group and the land face.
                go to the plugin menu and select instantroad and then road from centerline.
                follow the questions about the road.
                done.
                ok so maybe it's not soooo simple.
                By: Kristoff Rand
                • KrisidiousK
                  Krisidious
                  If you go to that link and scroll down there are a bunch of pdf's to teach you how to use it.
                  By: Kristoff Rand
                  • P
                    peebo22
                    Nope, I can't access...
                    http://i48.tinypic.com/2090m04.jpg
                    • KrisidiousK
                      Krisidious
                      404 Not Found
                      By: Kristoff Rand
                      • P
                        peebo22
                        I mean the PDF files. πŸ˜‰
                        @krisidious said:
                        404 Not Found
                        • KrisidiousK
                          Krisidious
                          http://www.valiarchitects.com/sites/default/files/tutorials/pdf/QuickStart-Road-from-CenterLine.pdf
                          here's a direct link... I'm not logged in so I don't know why you can't get there. But that image you show is a SketchUcation page now a Valiarchitect page.
                          By: Kristoff Rand
                          • P
                            peebo22
                            I mean Pilous link....if this is the tutorial working with terrain.
                            The instant road link works just fine.
                            Someone should write a good english tutorial how to work with triangulated terrain in sketchup. I really don't have clue, how to get the roads from the terrain. These roads are also in the real world, so I don't have to make new ones.
                            I've included a untouched SKP file which shows the situation. So, I want to make smooth terrain and the roads to it. You see they are there, but how can I "extract" them? And there's also other edgets, houses etc...
                            What is the first thing to do?
                            http://db.tt/FC7u5Hh5
                            here a [url=http://sketchucation.com/forums/download/file.php?id=85550:pc3zuuyx]PDF tutorial[/url:pc3zuuyx] about that by Daredevil
                            (sorry in French but with images and you can put the text in the [url=http://translate.google.fr/?hl=fr&tab=wT:pc3zuuyx]Google translator[/url:pc3zuuyx] πŸ˜‰
                            • S
                              sketchymick
                              Here's a bit more detail on the drape/stamp method: http://sketchucation.com/forums/viewtopic.php?p=393786#p393786
                              Cheers
                              -Mick
                              "I love the sound that deadlines make as they rush past"
                                Sorry it was on French Forum 😳
                                so here the direct file! πŸ˜‰
                                Route.pdf
                                • P
                                  peebo22
                                  Anyone got a clue from the skp file?
                                  • KrisidiousK
                                    Krisidious
                                    after looking at your file it looks like some type of 3D scan of a neighborhood. It already has a very detailed road in it and all of your geometry is one mass. If you want to separate the road from the land you'll need to go through and select every triangle and right click to make it a group. I would work in sections and then group them all together and explode them.
                                    By: Kristoff Rand
                                    • KrisidiousK
                                      Krisidious
                                      you can select more than one at a time but don't try to select all of them or it might make you start over if you slip. it might be easier to paint the road and then use the select same material on right click. then group.
                                      By: Kristoff Rand
                                      • P
                                        peebo22
                                        That would be painful.. 😞
                                        • KrisidiousK
                                          Krisidious
                                          yes it would....
                                          By: Kristoff Rand
