    Working with terrain (triangles)
    19 Posts 5 Posters 958 Views 5 Watching
    • KrisidiousK Offline
      Krisidious
      (www.valiarchitects.com)
      By: Kristoff Rand
        peebo22
        I mean the PDF files. πŸ˜‰
          Krisidious
          User account | Vali Architects | Instant Scripts
          here's a direct link... I'm not logged in so I don't know why you can't get there. But that image you show is a SketchUcation page now a Valiarchitect page.
          By: Kristoff Rand
            peebo22
            I mean Pilous link....if this is the tutorial working with terrain.
            The instant road link works just fine.
            Someone should write a good english tutorial how to work with triangulated terrain in sketchup. I really don't have clue, how to get the roads from the terrain. These roads are also in the real world, so I don't have to make new ones.
            I've included a untouched SKP file which shows the situation. So, I want to make smooth terrain and the roads to it. You see they are there, but how can I "extract" them? And there's also other edgets, houses etc...
            What is the first thing to do?
            http://db.tt/FC7u5Hh5
            here a [url=http://sketchucation.com/forums/download/file.php?id=85550:pc3zuuyx]PDF tutorial[/url:pc3zuuyx] about that by Daredevil
            (sorry in French but with images and you can put the text in the [url=http://translate.google.fr/?hl=fr&tab=wT:pc3zuuyx]Google translator[/url:pc3zuuyx] πŸ˜‰
              sketchymick
              Here's a bit more detail on the drape/stamp method: http://sketchucation.com/forums/viewtopic.php?p=393786#p393786
              Cheers
              -Mick
              "I love the sound that deadlines make as they rush past"
                Sorry it was on French Forum 😳
                so here the direct file! πŸ˜‰
                Route.pdf
                  peebo22
                  Anyone got a clue from the skp file?
                    Krisidious
                    after looking at your file it looks like some type of 3D scan of a neighborhood. It already has a very detailed road in it and all of your geometry is one mass. If you want to separate the road from the land you'll need to go through and select every triangle and right click to make it a group. I would work in sections and then group them all together and explode them.
                    By: Kristoff Rand
                      Krisidious
                      you can select more than one at a time but don't try to select all of them or it might make you start over if you slip. it might be easier to paint the road and then use the select same material on right click. then group.
                      By: Kristoff Rand
                        peebo22
                        That would be painful.. 😞
                          Krisidious
                          yes it would....
                          By: Kristoff Rand
