    Importing DWG
    layout
    6 Posts 5 Posters 786 Views 5 Watching
      seasdes
      Is there a way to import a DWG file into Layout 3. I would like to insert a surveyor's drawing and create a site plan in Layout.
      Walter
      Using Sketchup Pro 2019
      • FrederikF Offline
        Frederik
        Well...
        You can easily import a dwg in SU...
        Save it as a skp and then insert it in LayOut... πŸ˜„
        As I see it, there's no direct way you can import a dwg in LO...
        Perhaps it will come in the future...
        If the crew at Trimble implement the Ruby API, then I'm sure someone will be able to make this an option, where you can import it directly...
        Cheers
        Kim Frederik
          ArCAD-UK
          As Frederik says you can import via SU but once in LO if you view it in Vector mode you can then explode it to work on in LO.
          I wish there was some way to manage the text aspect but there doesn't seem to be a logical path at this time between the SU model & LO text overlay workflow.
          TIP: I recently tried to import a surveyors dwg file with curved polylines in it. SU imported as straight lines between survey points! I converted to dxf and the file came in as per the surveyors issued drawing. πŸ˜’
            seasdes
            I found a way to get DWG text into SU8. Firstly in ACAD convert all text to vector font. Then explode text into lines. This is readable in SU8 as if it were text.
            An alternative is to import DWG lines only into SU8. Then underlay a jpg file of the survey in SU8.
            Walter
              sonder
              Easy solution. Import the dwg into SU. Then copy paste into layout. Vector render it.....and your done.
              • P Offline
                pedrinalex
                Thanks for this tip Sonder
                Regards
                Pedro
                MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
