    Intersect solids plug-in ?
    5 Posts 3 Posters 420 Views 3 Watching
      awkonradi
      Hello All,
      Can anyone recommend a plug-in, which can process two overlapping solids, to generate the following three solids?
      (a) intersection of solid 1 and solid 2
      (b) in solid 1, but not in solid 2
      (c) in solid 2, but not in solid 1
      I recognize any of these outputs might consist of multiple fragments.
      For example, starting with the gray and blue solids in the attached file, I would like to cut the region of overlap from the gray object, and save the region of overlap as a new object.
      Thanks!
      Andrei
      intersect these solids.skp
        awkonradi
        And following some previous guidance, here is the file saved as Sketchup V6.
        intersect these solids skpv6.skp
          awkonradi
          OK, it appears I may be looking for free versions of the Solid Tools in the Pro version of Sketchup 8. Moderator, if this request is not appropriate, please delete. Thanks! Andrei
          • pbacotP Offline
            I think you want this: http://sketchucation.com/forums/viewtopic.php?t=14773#p112055 I have not tried it as I use v.8 Pro
            • cottyC Offline
              cotty
              Or, if you like to spend some money, you can try this by Whaat.
              my SketchUp gallery
