Intersect solids plug-in ?
Hello All,
Can anyone recommend a plug-in, which can process two overlapping solids, to generate the following three solids?
(a) intersection of solid 1 and solid 2
(b) in solid 1, but not in solid 2
(c) in solid 2, but not in solid 1I recognize any of these outputs might consist of multiple fragments.
For example, starting with the gray and blue solids in the attached file, I would like to cut the region of overlap from the gray object, and save the region of overlap as a new object.
Andrei
And following some previous guidance, here is the file saved as Sketchup V6.
OK, it appears I may be looking for free versions of the Solid Tools in the Pro version of Sketchup 8. Moderator, if this request is not appropriate, please delete. Thanks! Andrei
I think you want this: http://sketchucation.com/forums/viewtopic.php?t=14773#p112055 I have not tried it as I use v.8 Pro
Or, if you like to spend some money, you can try this by Whaat.
