    Need Help: export to Inkscape
    4 Posts 2 Posters 381 Views 2 Watching
    • T
      toddbg
      Hi Everyone -
      I am having a problem with a file, I need to export this to use in Inkscape.
      However when I bring this in as a svg, png or pdf I get streaks in the faces of the sketchup object.
      I need to be able to bring this in in some method that will allow me to get rid of those lines.
      link to sketchup file:
      https://dl.dropbox.com/u/199646/Temperance_testing.skp
      Link to Inkscape file:
      https://dl.dropbox.com/u/199646/scroll_drawing_greyscale.svg
      Thanks in advance.
      T
      • D
        driven
        turn on hidden geometry and erase coplanar edges
        • T
          toddbg
          Thanks for the response! I'll do that now.
          • T
            toddbg
            I got the edges cleaned up on the face of the letters.
            Is it possible to deal with the ones on the edge of the letters? So far every time I remove one (fn click with eraser on WIN) the whole surface is removed.
            Thanks again
