    Multiple Leader Lines for Single Text String
    8 Posts 4 Posters 763 Views 4 Watching
    • plesiosaurP Offline
      plesiosaur
      I am looking for plugin that creates multiple leader lines for a single line of text e.g.
      I have an exploded view with numerous parts, some of which are am iteration of the same part, I want to use one text entry with multiple leaders pointing the different iterations of the same part. Any suggestions? Thanks.
      • jeff hammondJ Offline
        jeff hammond
        kind of cheesy but i do it like this..
        one text entry is what you want it to say..
        the other text entry is a period which is positioned to overlap the 'T'..
        maybe make the first two characters of each leader the same and try to line those up
        meh..
        dotdotdot
          jeff hammond
          You may try to have a look at FredoTools::ReportLabelArea which has this capability.
          you need a marketing department
          not sure how i happened to miss this one..
          dotdotdot
          • fredo6F Offline
            fredo6
            Labels are created with the area of the elements selected but you are free to replace the text and move the anchors and text label by click and drag.
            Fredo
            • N Offline
              nickchun
              Likewise. I guess I wouldn't have looked for it under the Label Reporting title. You can also do it using Copy in Place but can't remember quite how. There is a mini tut on another site under 'tips and tricks' I think, but it can be fiddly. Fredo's solution looks easier.
                plesiosaur
                Thanks all, I use FredoTools as well but never thought to look there. Thanks again
                  plesiosaur
                  One note on Fredo Tools mentioned above: Be sure that the leader line format in the model info setting, Text>Leader Lines, the leader style must be set to Pushpin; if it is View Based you will get adverse results.
                  • fredo6F Offline
                    fredo6
                    If you wish to move the labels, either anchors or text part, just do it with ReportLabelArea, not with the native SU Tool.
                    Fredo
