    Push / Pull and Double Click
    3 Posts 2 Posters 344 Views 2 Watching
    • D
      danna
      Somewhere I read that you can select the push / pull tool, double click on something and it will extrude to the previous p / p distance.
      I had a few walls to extrude. I p / p the first to 10'
      Went to the next wall and hovered over the area until it was selected,
      double clicked p / p, and it was extruded the 10', but in the opposite direction.
      Where did I mess up ?
        Maybe your face with a negative PushPull is "blue" ! (reversed)
        Just Inverse it (Right Click / Reverse Face) and Push Pull will be fine πŸ˜„
        • D
          danna
          So simple ... at some point I'll start remembering.
          Thanks Pilou
