    Scenes.
    6 Posts 5 Posters 622 Views 5 Watching
      Bruce Watt
      I am having an issue with scenes.
      I set up my scenes for the model and then I have to create another layer for some reason or another. All the scene that were previously set up now have this layer set on. It is as though scenes remember the layers that are switched off not the ones that are switched on at the time of scene creation. I have to go back to each scene switch off the new layer and save the scene again. Is this right? what am I doing wrong! Any help would be appreciated.
      Many thanks
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
        I believe that you don't make mistake 😄
        Make animation with Layers is some painful!
        • Chris FullmerC Offline
          Yeah Bruce, that is the way it is setup to work. When you make a new scene, it is by default turned on in all scenes. The other default would be to turn it off in all scenes - who is to say which is right? Both are perfectly valid potential methods. SO, the dev team decided to have it turned on in all scenes.
          Someone made a plugin for this though. I just looked for it and couldn't find it. Anyone remember what its called?
          All my Plugins I've written
            Jim
            You can set the Layer visibility for all selected Scenes at once using the Scenes dialog.
            Use the Ctrl key (on Windows) to select multiple Scenes to update, then hit the Update button, and select just the "Layer Visibility" option.
            • cottyC Offline
              cotty
              Maybe
              Jims Add hidden layer
              or TIGs modified Version
              my SketchUp gallery
                Bruce Watt
                Thank you for your help, That all make sense now.
                Many thanks.
                Windows 10 Pro
                AMD Ryzen™ 9 3900X
