    Horn Throat Smoothing
    12 Posts 5 Posters 536 Views 5 Watching
    • P Offline
      panjilaras
      Hello
      this is front view of speaker horn.
      https://lh6.googleusercontent.com/-2hz_bPXCsfY/USSFT_9G6cI/AAAAAAAAAS8/zVEm2rk7EeM/s800/QT.jpg
      I would like to smooth the horn throat edges by making geometry that built upon face a, b, and c. How to do that?
      thank you very much
      have a great day, panji.
        Something like that ?
        If yes Round corner by Fredo6
        • ely862meE Offline
          ely862me
          Perhaps he want something more like this .. Make sure the quarters of the circle are curves not segments, then run the Extrude Edges by Rails from the Extrude tools plugin .
          Elisei (sketchupper)
          Come and See EliseiDesign
            I was thinking along the same lines as ely but I used Curviloft.
            So many ways.
            • ely862meE Offline
              ely862me
              At first I tried Curviloft too but I couldn't get a proper result .. How did you get that result ?
                I used "Skinning of Shapes" for that. I preselected the three curves and then ran the tool. I didn't even make any adjustments. I don't think preselecting the edges has anything to do with it.
                It occurs to me after looking at your images, that the OP might want to handle this differently, though. Your surfaces isn't continuous from the "horn" portion which he already had drawn. I wonder if the horn shouldn't be drawn to extend out into the square box and intersected with it.
                • ely862meE Offline
                  ely862me
                  The odd thing is that it doesn't work at all like that !
                  Will see about the shape when he answers .
                  1.skp
                    You're right. Your model is screwed up. πŸ˜„
                    It works on mine. I started with a box at the origin. I just deleted the top left corner so you can see the curves without orbiting.
                    curved surface.skp
                      Sand Box from contour, Soap Skin Bubble and Ferrari can give some similar results πŸ˜„
                      • ely862meE Offline
                        ely862me
                        The Extrusion tools gives the best result .
                        Dave, I tried your model and it won't work . There must be a glitch somewhere in my plugins !
                          Huh! I wonder what would cause that. As I said, I just selected the three curves and started the plugin and presto! It was done.
                          • Jean LemireJ Offline
                            Jean Lemire
                            Hi Panji, hi folks.
                            Of course, plugins will save you time but, if you want to try with basic tools, click in sequence on the scenes tabs of this SU file for ideas.
                            Horn throat.skp
