    Curved Surface from Circle to Rounded Square
    5 Posts 4 Posters 863 Views 4 Watching
    • D
      Ditchmond
      Newbie here. Been playing with Sketchup for a day or two now, and slowly starting to get the hang of it.
      Have a small issue that I can't seem to 'figure out' (as if my subject line wasn't confusing enough. So I've attached a few images to give you an idea.
      Basically I have the two surfaces (the circle and the rectangle with rounded corners below.
      I'm trying to create a arc surface that follows the edge of both those surfaces.
      These first two images show the two surfaces, and the one arc that I would like to create:
      http://www.ditchmond.com/images/misc/bcurve_03.jpg
      http://www.ditchmond.com/images/misc/bcurve_05.jpg
      And these two images show what happens after follow me. You can see they end up following the circle surface:
      http://www.ditchmond.com/images/misc/bcurve_01.jpg
      http://www.ditchmond.com/images/misc/bcurve_02.jpg
      This causes a issue with the overhang. I've tried picking both surfaces and running follow me, but it ends up using circle and causes that overhang.
      Any idea?
      • jeff hammondJ
        jeff hammond
        followme isn't a 2 rail sweep tool.. it can only have one profile follow along a single rail..
        you might want to look into a plugin such as CurviLoft to do this..
        http://sketchucation.com/forums/viewtopic.php?t=28586
        dotdotdot
        • D
          Ditchmond
          gah! Awesome! Thank you so much! Will look into it right now.
          • cottyC
            cotty
            And have a look at TIGs Extrude Edge by (EEbxxx) ... tools too.
            my SketchUp gallery
              Here square to circle πŸ˜‰
