    Drawing site plans
    5 Posts 4 Posters 703 Views 4 Watching
      rafleming
      All,
      I need some help drawing site plans for my architectural projects. I have a paper copy of the survey and in Autocad it would be as easy as drawing lines at the appropriate length (XX'-XX") and angle (XXD-XX'-XX"). please let me know if there is a plug-in for this or if its already in sketchup. thanks
      • pbacotP Offline
        Not a plugin suggestion, but you could just add the next line pointing to your zero axis, input length, hit your hot key for rotate and rotate, input angle. Are you using bearings? For that I am not sure about an easy way.
        • sdmitchS Offline
          sdmitch
          This plugin might be of some help. It expects Bearing and distance.
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=434
          http://sdmitch.blogspot.com/
          • KrisidiousK Offline
            Krisidious
            Yes as sdmitch says the survey tool is great. just what you're looking for. be-careful to start at the starting point.
            By: Kristoff Rand
              rafleming
              That did it. thanks for the help.
