    [Code] Quick Reference Card in a WebDialog
    15 Posts 5 Posters 1.2k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Display the Quick Reference Card in a WebDialog
      (Adds menu item to "Help" menu.)
      (Fixed menu item creation per thomthom's advice below.)
      #  Example to display the Quick Reference Card in a WebDialog.
      #  Adds a "Quick Reference Card" item to the "Help" menu.
      module Example
        module Qcard
          @@qcard = nil
          @@qcard_path = File.join(Sketchup.get_resource_path(''),"QuickReferenceCard.pdf")
          @@qcard_local = false
          if File.exist?(@@qcard_path)
            @@qcard_local = true
          else
            iver = Sketchup.version.to_i.to_s
            plat =( RUBY_PLATFORM =~ /(darwin)/i ? 'Mac' ; 'Win' )
            @@qcard_path = "http://dl.google.com/sketchup/gsu#{iver}/"
            @@qcard_path << "docs/en/SketchUp#{iver}Refcard#{plat}.pdf"
          @@say = { 'menu item text' => 'Quick Reference Card' }
          class << self
            def qcard
              unless @@qcard
                @@qcard = UI;;WebDialog.new(@@say['menu item text'],true,'Help_Qcard',1000,783,50,100,true)
                if @@qcard_local
                  @@qcard.set_file( @@qcard_path )
                else
                  @@qcard.set_url( @@qcard_path )
              if @@qcard.visible?
                @@qcard.bring_to_front
              else
                RUBY_PLATFORM =~ /(darwin)/i ? @@qcard.show_modal ; @@qcard.show
          end # proxy class
          unless file_loaded?('Example;;Qcard')
            if Sketchup;;Menu.instance_method(;add_item).arity == 1
              UI.menu('Help').add_item(@@say['menu item text']) { qcard() }
            else
              UI.menu('Help').add_item(@@say['menu item text'],3) { qcard() }
            file_loaded('Example;;Qcard')
        end # module Qcard
      end # module Example
      I'm not here much anymore.
        driven
        hi dan
        coming up blank, but no errors,
        if I linefeed the path bits and the WD bits, it appears in a pdf reader view... like it should.
        can't see why it's not running when intact?
        john
          slbaumgartner
          On my Mac, the WebDialog opens and spins a bit and then SketchUp crashes.
          Steve
            <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">version</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i&nbsp;</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault">7<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Help'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(@@</span><span class="syntaxdefault">say</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'menu&nbsp;item&nbsp;text'</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">qcard</span><span class="syntaxkeyword">()&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Help'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(@@</span><span class="syntaxdefault">say</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'menu&nbsp;item&nbsp;text'</span><span class="syntaxkeyword">])&nbsp;{&nbsp;</span><span class="syntaxdefault">qcard</span><span class="syntaxkeyword">()&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span>
            The second argument wasn't added in the first SU8 release. A safer way is to test for functionality instead of version (like you do in webdesign: test for features instead of user agent strings)
            <span class="syntaxdefault"><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_method</span><span class="syntaxkeyword">(;</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">arity&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Help'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(@@</span><span class="syntaxdefault">say</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'menu&nbsp;item&nbsp;text'</span><span class="syntaxkeyword">])&nbsp;{&nbsp;</span><span class="syntaxdefault">qcard</span><span class="syntaxkeyword">()&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Help'</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(@@</span><span class="syntaxdefault">say</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'menu&nbsp;item&nbsp;text'</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">)&nbsp;{&nbsp;</span><span class="syntaxdefault">qcard</span><span class="syntaxkeyword">()&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br /></span>
              Dan Rathbun
              @thomthom: Fixed OP code post per your good advice.
              @others: This code is really a test to see how the WebDialog handles both local and remote PDF documents without a wrapping HTMl page. (Just letting the browser control load the PDF viewer.)
              (1) The reason I have a check for a local PDF file, in the localized resource directory, with the exact filename "QuickReferenceCard.pdf", is because that was what was designed into SketchUp via:
              Sketchup.send_action(21466)
              which opens the file using Adobe Reader, if it exists, and displays "Cannot find file.." messagebox if it does not.
              Apparently, they were planning on having multi-language "Qcards" but never got beyond creating just the English edition.
              (2) There is really a problem remotely accessing the PDFs on the download.trimble.com site because of the expiration and unique signature fields.
              Even on PC, it loads the first time in a session, but not if you close the dialog, and re-open it.
              Likely it will work faster if the file is local.
              They can be downloaded here:
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=116693
              No easy way via the API to download and save a file into the local resources folder. (Basically a bad idea, because this is an application "owned" folder.)
              (3) Not going to create a plugin from this... just testing. Perhaps Alex or someone else who already has a Help/Reference extension, can add this feature in.
              (4) Also.. too bad the card is not in HTML, or a translator could translate it.
              (And it could be updated to say "Trimble" instead of "Google".)
                Dan Rathbun
                Well for a local file, do you need to prepend "localhost://" or "file://" on the Mac ?
                IE, we might need to insert a conditional for Mac that prepends whatever is needed.
                I think the remote problems are in the way that the download site is set up. If the PDF files were just in a directory allowing ftp access, there would not be a problem.
                  Dan Rathbun
                  And you like it in a separate window (rather than a child window that is always on top,) the equiv. for the integer action would be something like:
                  UI.openURL(@@qcard_path)
                  So on my machine where Chrome is my default browser:
                  UI.openURL('http://dl.google.com/sketchup/gsu8/docs/en/SketchUp8RefcardWin.pdf')
                  ... opens it remotely but in a Chrome tab.
                  • alexschreyerA Offline
                    alexschreyer Extension Creator
                    Thanks for the tip! I should really add it to the RCE.
                    With regards to loading from web failing: Have you tried adding a random number parameter to the end of the URL, so that it doesn't get cached by IE? As in: http://dl.google.com/sketchup/gsu8/docs/en/SketchUp8RefcardWin.pdf?p=randomnumber
                    Author of "Architectural Design with SketchUp":
                    http://sketchupfordesign.com/
                      Dan Rathbun
                      No I did not try that.
                      Did you open IE and paste in the url, so you can see the hidden input fields ?
                        driven
                        @all,
                        Retested latest version [with TT's bit] and it all works on my mac...
                        john
                          slbaumgartner
                          @driven said:
                          @all,
                          john
                          I now get a blank window. John, do you have a custom WebKit installed? Or some kind of PDF viewer plugin?
                          Steve
                            driven
                            Are you insinuating that I may have tampered with my SU instal;)
                            I have the standard WebKit
                            SU WebDialog doesn't seem to use Safari's
                            WebKit built-in PDF
                            — from file “”.
                            MIME Type Description Extensions
                            application/pdf Portable Document Format pdf
                            but instead seems to be using
                            Adobe Acrobat and Reader Plug-in
                            Adobe Acrobat and Reader Plug-in for Web Browsers, Version 9.5.2 — from file “AdobePDFViewer.plugin”.
                            have a look what yours are...
                            html=%q(
                            <html>
                                <head>
                                    <meta http-equiv="content-type" content="text/html; charset=UTF-8">
                                    <title>Installed Plug-ins</title>
                                <style type="text/css">
                                        body { color; #555; }
                                        div#margins { margin; 5%; }
                                        div.plugin-name {
                                            margin-top; 2em;
                                            margin-bottom; 1en;
                                            font-size; large;
                                            font-weight; bold;
                                            color; black;
                                        table {
                                            background-color; #F5F5F5;
                                            color; #222;
                                            font; message-box;
                                            width; 100%;
                                            border; 1px solid #222;
                                            border-spacing; 0px;
                                        th {
                                            text-align; center;
                                            font-weight; bold;
                                            background-color; #CCC;
                                        th + th, td + td { border-left; 1px solid #AAA; }
                                        td               { border-top; 1px solid #AAA;  }
                                        th, td           { padding; 3px; }
                                        td.extensions    { text-align; center; }
                                        th.MIME-type     { width; 30%; }
                                        th.description   { width; 50%; }
                                        th.extensions    { width; 20%; }
                                    </style>
                                </head>
                                <body>
                                    <div id="margins">
                                        <script type="application/x-javascript">
                                            // Localizers; Translate the title above, and these six strings, and leave the rest of the file intact.
                                            var InstalledPlugIns = "Installed Plug-ins";
                                            var BetweenDescriptionAndFilename = " &mdash; from file &ldquo;";
                                            var AfterFilename = "&rdquo;.";
                                            var MIMETypeColumnHeader = "MIME Type";
                                            var DescriptionColumnHeader = "Description";
                                            var ExtensionsColumnHeader = "Extensions";
                                            // Now the code.
                                            navigator.plugins.refresh(false); // Supposedly helps if new plug-ins were added.
                                            var plugins = [];
                                            for (var pi = 0; pi < navigator.plugins.length; pi++) {
                                                plugins.push(navigator.plugins[pi]);
                                            plugins.sort(function(a, b) {
                                                return a.name.localeCompare(b.name);
                                            for (var pi = 0; pi < plugins.length; pi++) {
                                                var plugin = plugins[pi];
                                                document.writeln("<div class=\"plugin-name\">" + plugin.name + "<\/div>");
                                                document.writeln("<blockquote>" + plugin.description + BetweenDescriptionAndFilename + plugin.filename + AfterFilename + "<\/blockquote>");
                                                document.writeln("<table class=\"types-table\">");
                                                document.writeln("<thead><tr>");
                                                document.writeln("<th class=\"MIME-type\">" + MIMETypeColumnHeader + "<\/th>");
                                                document.writeln("<th class=\"description\">" + DescriptionColumnHeader + "<\/th>");
                                                document.writeln("<th class=\"extensions\">" + ExtensionsColumnHeader + "<\/th>");
                                                document.writeln("<\/tr><\/thead>");
                                                document.writeln("<tbody>");
                                                for (var mi = 0; mi != plugin.length; ++mi) {
                                                    document.writeln("<tr>");
                                                    document.writeln("<td class=\"MIME-type\">" + plugin[mi].type + "<\/td>");
                                                    document.writeln("<td class=\"description\">" + plugin[mi].description + "<\/td>");
                                                    document.writeln("<td class=\"extensions\">" + plugin[mi].suffixes + "<\/td>");
                                                    document.writeln("<\/tr>");
                                                document.writeln("<\/tbody>");
                                                document.writeln("<\/table>");
                                        </script>
                                    </div>
                                </body>
                            </html>
                            dlg = UI;;WebDialog.new("Instaled_Webkit_Plugins", true,
                               "ISP", 739, 641, 150, 150, true);
                             dlg.set_html(html)
                             dlg.show_modal
                              driven
                              @Dan,
                              sorry for the detour...
                              I just disabled 'Adobe Reader' and it doesn't 'list' the alt "webKit PDF plugin", but it did open in it,
                              and it includes the option to open in Preview.app, from which I can 'save as' at the 'correct' local path.
                              if I then add, as suggested...
                              @@qcard.set_file( "file;///" + @@qcard_path )
                              it is working locally and I don't get the 'access denied' if I do a manual reload of the page...
                              on my mac your test now appears to be functional.
                              john
                                Dan Rathbun
                                OK so, ... to display PDF in a WebDialog (on either platform,) the user must have installed Adobe Reader plugin for their browser ??
                                IF true.. (for the case of a "qcard",) it might be easier to convert the Quick Reference Card to HTML. (Which can be translated more easily?)
                                This test was really about displaying PDFs in a WebDialog, and I used the "qcard" as the test file.
                                Maybe the conclusion is that PDFs are problematic ??
                                  slbaumgartner
                                  WebKit built-in PDF
                                  — from file “”.
                                  Nice plugin scanner, John!
                                  I got
                                  Adobe Acrobat and Reader Plug-in for Web Browsers, Version 9.0.0 — from file “AdobePDFViewer.plugin”.
                                  So maybe there's a version sensitivity involved? In any case, it seems to support Dan's feeling that PDF display via WebDialog is not reliable from machine to machine..
                                  Steve
