    Need advice: offset about complex shape
    8 Posts 4 Posters 624 Views 4 Watching
    • dereiD
      derei
      I have this tree sketch and I want to use it on a CNC machine... but, before that, I would like to make a 3d representation of the final result, so I need to "emboss" that shape into a face, but having a thickness of 5mm.
      I tried Lines2Tubes, but the model seem too complex and crashes every time. It worked at first, but it creates odd ends where tubes intersect.
      Any suggestions? Any plugin that emulates the shape of a CNC head over a path?
      Thank you.
      SketchUp Model
      DESIGNER AND ARTIST DEREI.UK
      • sdmitchS
        sdmitch
        It wasn't a problem making everything other than the tree trunk into a face but had to add multiple lines across the tree trunk to form faces then erasing the lines to leave a single face.
        Or was it something else entirely that you were trying for?
        You might try scaling everything up 1000x and retry Lines2Tubes since Sketchup doesn't do well with small faces.
        Tree Sketch.skp
        http://sdmitch.blogspot.com/
        • dereiD
          derei
          Actually, what I want is something like this... but even scaling the model 1000X, it still crashes, and I cannot figure why. This is the most I could do, if I select more, if blows.
          Lines2Tubes -> Zorro on the midline, deleted both sides, cleaned-up => voila !
          I hoped that is possible to automate the process, like an Offset tool that will do it for all lines in this sketch.
          • GaieusG
            ...Lines2Tubes -> Zorro on the midline, deleted both sides, cleaned-up => voila !
            Nice solution!
            That would be a good idea for a plugin.
              Try City Streets Generator by Thomthom πŸ˜‰
              and you can choice the round angle, thickness, and even make blocks πŸ˜‰
              http://sketchucation.com/forums/download/file.php?id=42058&mode=view/rokbox.jpg
              Clean Up by Thomthom
              Make Face by Tod Burch
              • sdmitchS
                sdmitch
                After rotating everything to the XY plane, I was able to achieve this result using my Dashline plugin. It took a couple of minutes to process when selecting everything.
                • dereiD
                  derei
                  Well, your trick ALMOST offers the wanted result... but it doesn't.... as you can see in this image, there are a lot of gaps that resulted from rotation.
                  I have to try Pilou's solution.
                  • dereiD
                    derei
                    Crib.png[/attachment]It took me A LOT of cleaning... but Street Generator was a good solution... And I swear I never do this again πŸ˜† (until my OCD strikes again next time)...
                    [attachment=0]
