    Finding start and end point of a component
    4 Posts 3 Posters 354 Views 3 Watching
    • D
      Davidfi1
      I need to find the two points of the top line inside an instance of a component.
      At first it looked like an easy task, but when I tried actually doing it,
      I found out it is not that easy.
      sampleTest
      I need to run a ruby script and get the [x,y,z] of the points that are measured.
      can you help pleas?
      Thank you.
      • thomthomT
        Would need more context to how to you want to determine these points.
        Is the object always this configuration?
        Is it based on what vertices have dimension objects attached?
        Are you trying to make a custom tool to pick the points?
        A use-case would be good because the question is currently to ambiguous with too many possible answers.
        Also, what have you tried?
        • TIGT
          The component instance has a boundingbox - see the API docs.
          bb=obj.bounds
          From that you can find its 8 corners.
          You can also find things like its min/max/center.
          So for example you can find the two points that define one bottom-end edge, find the point mid-way between them, and change its z.value to bb.max.z.
          You can repeat this for the other end's vertices.
          Then you have two Point3d references with the needed XYZ ?
          BUT if for example this 'ridge' is not central or perhaps it's even not level, and you want to find its end points 'in the model' then an alternative is to find all edges in the edges=instance.definition.entities.grep(Sketchup::Edge), then sort through their vertex points for the two highest... and those are then the two points you need [almost] - let's call them pt1 and pt2. Find the 'transormation'... tr=instance.transformation and then apply that to the two points ( pt1.transform!(tr) and pt2.transform!(tr)) and they will then be the points you want to get the XYZ from...
          • D
            Davidfi1
            This
            @tig said:
            (pt1.transform!(tr) and pt2.transform!(tr))
            worked very nicely.
            Thank you.
