    Emissive reflection don't work [Vray]
    extensions
    4 Posts 4 Posters 774 Views 4 Watching
    • Y Offline
      yann57
      Hello everybody !
      I made an emissive material and I don't know why, the reflection in the window isn't correct (It's like a standard material) ! Is anybody has a solution ?
      I use Skp 8 and Vray 1.49
      Thanks !
        Hi Yann,
        What application?
        • FrederikF Offline
          Frederik
          @gaieus said:
          What application?
          Cheers
          Kim Frederik
          • V Offline
            valerostudio
            Did you check to make sure your faces are front facing? It could also be a bug with emissive materials. I am not sure because I have never run into this problem because I say clear of emissive materials for the most part.
