    [Bug] Sketchup.write_default on Mac
    6 Posts 5 Posters 460 Views 5 Watching
    • T
      tomasz
      I have a problem with storing UTF-8 string into "default settings" on Mac.
      ` Sketchup.read_default("MySettings","MyKey")
      nil
      Sketchup.write_default("MySettings","MyKey","Test")
      true
      Test
      Sketchup.write_default("MySettings","MyKey","Bล‚ฤ…d")
      true!
      nil!!`
      Is there any encoding that would let me store the UTF8 string into the default settings on Mac?
      Where can I locate the ini file SketchUp stores the data?
      Tomasz
      • jeff hammondJ
        jeff hammond
        Tomasz
        (non developer response below.. proceed with care ๐Ÿ˜‰ )
        i think you're looking for the .plist file on mac instead.. in which case, it's at
        user/ Library/ Preferences/ com.google.sketchuppro8.plist (or whatever SU version)..
        note*-- user library is hidden on new mac OSes..
        dotdotdot
        • AdamBA
          AdamB
          As Jeff says, on a Mac its stored as some XML (with a .plist extension)
          Why don't you just escape it:
          Save it as Sketchup.write_default("MySettings","MyKey", "Bล‚ฤ…d".unpack('H')[0])*
          Load it as Sketchup.read_default("MySettings","MyKey").to_a.pack('H')*
          Tadaa!
          • T
            tomasz
            Thanks. Have fount it. Everything is written fine there!
            It is the read method that doesn't convert it back to UTF8, I guess.
            Btw. I have found MainFrame_M2Upgrade Boolean entry ๐Ÿ˜„ (switched off)
            Tadaa!
            Thanks. You are right.
            I was thinking of reading the file from C++, but it is too much to find the right one. Old Ruby way will work better.
            I will report the bug.
            • thomthomT
              Yea, the attributes seem to be picky about what you can store, without giving much hints to what is accepted - nor tell you when something fails.
              To store data, non-text, I've been using Base64.
              • Dan RathbunD
                Dan Rathbun
                Keep in mind that read_default passes the attribute text through eval() before it is returned, apparently with a rescue nil clause (or modifier.)
                This is why we cannot have any un-escaped embedded double-quote characters in the attribute.
                I'm not here much anymore.
