Render[in] texture issue/question
Had this error message come up. The only texture images missing are my flooring in the render... how can I fix this? How is access affected when this texture is with all the others? Thank you**[highlight=#ffffff:2tt59j68][color=#000000:2tt59j68]][/color[/highlight:2tt59j68]**
Render[in]
Failed to read textures.
Please make sure you have read access to the folder:
"/var/tmp" -
I am having the same problem - any chance you found a solution in the year since you posted this?
Register LoginAdvertisement
