    2sided material unknow problem !
    renderpluginsextensions
    3 Posts 2 Posters 309 Views 2 Watching
    • Y Offline
      yann57
      Hello everybody,
      I tried to make my first 2 sided material, but I got some problems with my render,
      When i render everything is ok it looks normal, (I can see the light trough the shade even the reflection of the light) but when the the render is completed the shade looks like a standard material : any texture, any light comes trough.
      I use sketchup 8 and Vray 1.49
      Any suggestions ?
      Thanks !
      (Sorry for my english)
      • andybotA Offline
        andybot
        Make sure you are adding the texture to the base material, not the new "Default" material that you create when you add the 2-sided material. It will revert to a regular texture if you edit the 2-sided material in the SU material editor.
        • Y Offline
          yann57
          Thanks it works !
