    Shadow Problems
    5 Posts 3 Posters 247 Views 3 Watching
    • P Offline
      Penguin2
      Have been working on a Site Model for a few days and generally things have been OK until today.
      My Shadows seem to be casting on a flat plane on parts of the model and other areas appear to be fine. (please see attached).
      Sorry to trouble you again but can anyone come to the rescue?
      Many thanks.
      Andrew
      • gillesG Offline
        gilles
        Some of your model might be under the origin. Move up the whole model
        • gillesG Offline
          gilles
          Or in shadows window uncheck on the ground.First click on the little white + top right of the window to display all parameters.
            Not "might be." Part of your model is below the ground plane.
            • P Offline
              Penguin2
              'On Ground' Shadows Setting was checked and yes there are Ground Level Issues.
              Just started introducing Contours and used Sandbox for the first time a couple of days ago (what a great feature Sandbox is).
              Thanks again.
              Panic over.
              Regards,
              Andrew
