    Exporting .kst PROBLEM!! ANIMATION PROBLEM in KERKYTHEA
    extensions
    3 Posts 2 Posters 1.0k Views 2 Watching
    • T
      tabibito
      Hi all,
      I have no idea if this is a common problem but I have been running trough the forum and I can not find anything on this specific problem.
      I would like to export from SU an animation but everytime I try to export the .kst file nothing saves.
      This is the text in the Ruby Console when I try it:
      Error: #<Errno::EACCES: Permission denied - porta aire.xml>
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/su2kt.rb:2975:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/su2kt.rb:2975:in new'
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/su2kt.rb:2975:in animation' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/su2kt.rb:3447 /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/su2kt.rb:2975:in call'
      What to do? Any help would be appreciated...
      Also I see just before I click save there is no indication that what file format its saving, and there are none to choose from.
      Again any help would be appreciated.
      Thanks!
      • T
        tomasz
        Welcome to the SketchUcation forum.
        It is not welcomed to use whole words in Capital letters in your posts, not mentioning message headers. It is being read as shouting.
        You are trying to save the .kst file in a location SketchUp Ruby cannot save (it doesn't have permission).
        Error; #<Errno;;EACCES; Permission denied - porta aire.xml>
        Try saving in a different location, your are sure you have full access to. You don't have to specify the extension.
        You cannot select a file type in the save dialog, because Ruby API doesn't work as it should.
        I would recommend registering in Kerkythea forum. You will get very accurate and fast response there to you KT related questions.
        • T
          tabibito
          Thanks tomasz, sorry if I shouted, it wasn't my intention... I'm beginner in forums use, so I'm still learning... it will no happen again πŸ˜„
          About the exportation problem. I tried to save in a location I have full access to, and I tried to save it without specifying the extension. Still nothing.
          By the way, I'm working in Mac, I don't know if it makes any difference.
          I posted this question a month ago in Kerkythea forum, but I didn't get response, that's why I'm trying now here. Anyway I'll try it again.
          Any idea?
          Thanks again.
