    Help in Creating an "empty" sphere
    3 Posts 2 Posters 249 Views 2 Watching
    • R
      reversi
      Hi everybody,
      i just started using Sketchup, so sorry if my question could look stupid...
      I am trying to create a sort of empty sphere (see attachment) with a missing piece (a sort of 3/4 "nest")
      I started creating a "bowl" with the follow-me tool. Then i duplicated it and tried to rotate the second bowl.
      My aim is to intersecate model, to obtain a unique component..
      Unfortunately the two bowls never fit.. is there a way to make them fit perfectly?
      Is my procedure right or is there something i miss?
      The final goal is to "slice" the component with slicer plugin, then print it wit the "Gk postscript Plot" plugin.
      Unfortunately i need a perfectly fitting "nest".
      Thanks again for your help,
      Simone
      ![the two bowls of this "nest" should fit perfectly, so i could slice the component having perfect circles.](/uploads/imported_attachments/G8YQ_empty_sphere_test.png "the two bowls of this "nest" should fit perfectly, so i could slice the component having perfect circles.")
        Take your global sphere with thickness
        then Make a bolean Operation if you have the Pro version or an intersection with a free version
        Sphere / box πŸ˜‰
        Or More easy
        take the double Sphere
        Show Hidden Geometry
        In any view face - top - Side
        Enable view camera Parallel Projection for a more easy selection
        Just select with the rectangle selection that you don't need! πŸ’­
        • R
          reversi
          thank you very much Pilou!
          this is way faster and easy!
          have anice day,
          Simone
