    Reducing thickness of outline of skp model for export
    15 Posts 4 Posters 870 Views 4 Watching
    • tibetT Offline
      tibet
      hi,
      when i reduce my model and like to export it into 2D eps file,
      the thickness of outline is unbearable / see below
      is there any chance to find setting and reduce it into eg. hairline ?
      http://img.sceper.eu/images/tMqWY.jpg
      ( eps file and jpg file together )
      what is the shortest way to export a big model into eps file, without
      manual reducing?
      if i export model in jpg ( instead of eps ) the lines of model are distorted.
      http://img.sceper.eu/images/cMpH3.jpg
      your valuable tips and advices are very appreciated!
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
      • cottyC Offline
        cotty
        For pixel graphics (jpg), you can increase the exported size which reduces the line width...
        my SketchUp gallery
        • tibetT Offline
          tibet
          hi
          thanks for a tip.
          a did it, but it wasn´t much better.
          i´m sorry we can set dpi in SU.
          anyway,it was worth a try.
            You can effectively control DPI in your image export. Try using a PNG export instead of EPS.
            This is the same line style exported at 5 different pixel width settings. The higher the resolution, the thinner the lines when viewed at a fixed size.
            • tibetT Offline
              tibet
              hi dave,
              thanks for reply, it´s pretty cool !
              if you like to share some other interesting tips, please do not hesitate 😄
              best of luck!
                You're welcome George. So are you going to try that with your fence model? I'd be interested to see what you get.
                • tibetT Offline
                  tibet
                  hi,
                  i´ve been trying, but i must do something wrong, because the final result
                  is the same 😞
                  could you please have a look, when you get time?
                  thanks for understanding
                  i like to learn making nice and smooth things.
                  my skp model is here: http://bitshare.com/files/61ssemxe/1.skp.html
                  preview is attached below
                    I'd be happy to take a look at your SKP file but I refuse to download files from BitShare. I started to do so for your file and got a popup to a sex site. Fortunately my employer's firewall blocked it. Your files are worth risking my job for. Just upload the SKP file here on SCF.
                    • tibetT Offline
                      tibet
                      hi,
                      i´m sorry to hear you couldn´t get the file, i never got any popups.
                      i use adblock plus with firefox.
                      ( choose regular download, wait for 50 seconds, and download it )
                      of course, i never want to make anyone trouble.
                      the file was over 4MB, so i couldn´t uploaded to the site.
                      i´ve just purched unused of colors and components, and whole model
                      reduced size from 4MB to 386KB.
                      it´s unbelievable!
                      thanks
                      2.skp
                        It's a good idea to purge unused stuff once in awhile. 😉
                        Hidden Line Image Exported at 4000 px wide
                        Hidden Line Image Exported at 6000 px wide, resized to 4000 px wide
                        How thin do you want the lines to be?
                        • tibetT Offline
                          tibet
                          hi,
                          thanks for your excellent visualization of the model!
                          well, because i haven´t found outline setting in SU , i´d
                          preffer to do as small as possible
                          in CorelDRAW is easy :
                          http://img.sceper.eu/images/kxUcv.jpg
                          when i use eps files, the lines are smooth, without any distortion.
                          this is the reason , why i´s taking about it 😄
                          anyway, do you use special settings or plugin to achieve the best effect?
                          best of luck!
                            No plugins for this.
                            File>Export>2D Graphic... I set the file type to PNG and click on Options. There I choose the desired pixel width. Couldn't be easier.
                            An EPS export doesn't give you that option.
                            What are you going to do with the images once you have them out of SketchUp?
                            Upload your images in your threads, too. 😒
                            • Mike LuceyM Offline
                              Mike Lucey
                              ..... another Masterclass by Dave R ...... thanks Dave. I always have something to learn from you 👍
                                Thanks, Mike. 😉
                                • tibetT Offline
                                  tibet
                                  hi,
                                  i did a quick model of metal fence with authomatic gate, but the photographs ( i was given ) wasn´t good quality, and without proper angles to use it for photomaching.
                                  when i get the final one, i´ll post it.
                                  i´m a bit shy, to show my simple models among unique and amazing artist works around here.
                                  thanks for understanding 😆
                                  best of luck
