    Lost tips and info bottom left ....
    3 Posts 2 Posters 445 Views 2 Watching
    • D
      danna
      Lost tips and info that shows when a tool is selected at bottom left of screen.
      Not sure how I turned it off.
      Measurement/dimension box is still showing lower right.
      • M
        mrossk
        Found this in the Help info: "
        The Measurements Box has disappeared.
        The "Measurements Box", or "Value Control Box (VCB)" in previous versions of SketchUp, is located in the lower-right corner of the SketchUp window. If you can't see it, the most likely reason is that your SketchUp window size is larger than your available screen viewing area. In that case, the bottom status bar of the SketchUp window, which includes the "Measurements Box," can be hidden behind the Windows taskbar (the bar that contains the "Start" button).
        To recover your view of the "Measurements Box," maximize the SketchUp window by clicking the "Maximize" button, which is in the upper-right corner of the SketchUp window, to the left of the "Close" button (the red button with a white "x").
        Note: One way this situation can happen is if you have been using the auto-hide taskbar option, have manually resized the SketchUp window to fill most of the screen, and then turned off the "Auto-hide the taskbar" option.
        https://www.mkaplanfinefurniture.com/
        • D
          danna
          That's what it was.
          Looked full screen but actually wasn't.
          Thanks mrossk
