    Groups on faces like rhino
    16 Posts 4 Posters 862 Views 4 Watching
    • yitzharY Offline
      yitzhar
      im looking for a tool that can work a little bit like rhino ..
      a tool that can take one group and put it on a curved grid on face ..
      because the grid will be curved the group should rechange in each space and together
      they all will create 3d face ...
      it will help to make architecture facade?
      any plugin ?
      look for us on facebook : creatioIL
      • yitzharY Offline
        yitzhar
        i dont have screen shot it only an idea i thought of ..
        and yes its should deformed on each paneling
          Seems paneling has success today πŸ˜„
          But put an detailed image of what you want exactly!
          The module must be deformed or not ?
            You are not satisfy by this solution ?
            • sdmitchS Offline
              sdmitch
              I have a plugin that I have worked on for the past 18 months that attempts to do what you are describing and have had some limited success. I would appreciate it if you would post a model with an example of your vision of this problem that I could test.
              http://sdmitch.blogspot.com/
              • jeff hammondJ Offline
                jeff hammond
                these .skps are 40MB + so i can't attach them..
                one thing you could do with such a plugin (and really, this doesn't even scratch the surface.. nor does it really give the idea of what's going on.. i'll try to find some videos which show it better)
                OR.. this or that :) ...etcetc..
                dotdotdot
                  jeff hammond
                  paneling tools -- basic
                  dotdotdot
                    jeff hammond
                    more basics...
                    dotdotdot
                    • sdmitchS Offline
                      sdmitch
                      Jeff, so far I have been able to accomplish example #1 as demonstrated in the video.
                      Page Not Found
                      Web word processing, presentations and spreadsheets
                      (docs.google.com)
                      ps. what does it take to get Google Drive links accepted as a video in the normal
                      option?
                        jeff hammond
                        wow.. that looks cool so far
                        (fwiw, there are a couple of threads going on around here this week which are along these lines.. just to be clear, my personal view on it is that sketchup simply isn't the right foundation to be building a set of tools like this for and a ruby writer will have to be a mad scientist type to try to do it πŸ˜† ... personally, i use other software that's already capable to handle the amount of geometry created by such an operation and i (again, personal opinion) don't think sketchup needs or is truly able to deal this type of function..
                        option?
                        i'm not sure.. csaba probably knows though.
                        dotdotdot
                          About deformations after paneling LSS Matrix by Kirill2008 can make the trick ?
                          • sdmitchS Offline
                            sdmitch
                            Jeff, I totally agree after butting head angainst this brick wall for some time. Even when it works, a surface of any size takes a lot of time to calculate.
                              Just a little question for precision πŸ˜„
                              On the second Rhino video does the modules have a "flat bottom" on the curvated surface Target or theses bottom's modules themselves are curvated following the surface target ?
                              @Sdmitch
                              I don't see Panel in your List of Plugins?
                              Does this one always in WIP ?
                              • sdmitchS Offline
                                sdmitch
                                Pilou, No isn't there because I never fealt that it was ready for publication.
                                  jeff hammond
                                  in the command options, you can choose to either 'pull to surface' in which case, the geometry will conform to the actual surface -or- deselect that option and the geometry will simply span the grid points in straight lines while ignoring the actual curvature of the surface..
                                  [and in that video, the author is pulling the curves to the surface.. watch at 1:02 when he mentions that option]
                                  [eDit]
                                  for example.. if i want to panel this cone on a cylinder, i have 2 options regarding how it deals with the surface..
                                  the cone module along with the target surface (divided in such a way that the cone will deform upon placement)
                                  the cone module being pulled to the cylinder surface..
                                  placement of the cone while ignoring the surface..
                                  dotdotdot
                                    @Sdmitch
                                    courage that will be a very cool plugin! 😎
                                    (if Kirril2008 don't make it before)
                                    @Jeff
                                    Thanks for precisions, i had suspected that, so that is a truelly tricky Rhino plugin! β˜€
                                    (i believe i can make the same with Moi, I will see that πŸ˜„
