    Moving Axis / Origin of a Group
    3 Posts 2 Posters 224 Views 2 Watching
    • M
      Minne Danhieux
      Problem: I have lots of groups. I Want to select them. Execute a ruby plug and the Axis/Origing of everygroup is moved to a random location.
      I tried setting transformation.axes but this only tranforms everything inside the group leaving the Axis / Origing to its original position. I found many Similar question and problems but its realy misty on how to do this correct,clean and fast!
      Thx in advance guys. πŸ˜„
      • TIGT
        You make a transformation
        tr=Geom::Transformation.translation(vector)
        and apply it to the group as:
        group.transform!(tr)
        to move it by that vector.
        You can generate a random vector ...
        If you want to - to move the contents of the group back, so that although it appears to be unchanged its axes are now elsewhere use:
        group.entities.transform_entities(tr.inverse, group.entities.to_a)
        • M
          Minne Danhieux
          Tig, ok this did the trick! THX! πŸ˜„
