    Add entities to a layer
    6 Posts 3 Posters 325 Views 3 Watching
      sachi
      Dear all,
      i want to control the visibility of several components in my model. to do that i add a new layer to the model. now i want to assign those components to newly added layer(new_layer). how could i assign those components to the new layer?
      theoretically there should be something like
      new_layer.add component_entity
      help me.thanks in advance
      • Chris FullmerC Offline
        The work flow is more like:
        layer = Sketchup.active_model.layers.add "My New Layer" component_entity.layer=layer
        http://www.sketchup.com/intl/en/developer/docs/ourdoc/drawingelement#layer=
        Good luck!
        All my Plugins I've written
          As Chris says...
          You add an entity into an entities 'collection'.
          Like model.entities, group.entities, definition.entities etc.
          An entity can then be assigned a layer: entity.layer=my_layer
          It's advisable NOT to assign layers to 'raw geometry.'
          This will lead to confusion...
          Assigning a .layer= is the same as you do to assign a .material=, .hidden=[true/false] and so on.
          Layers are used to control objects' visibility, not to separate geometry - that separation is done using a 'container' like a group or definition, the container can then have a layer assigned too...
            sachi
            thank you very much.it worked.i tested it for a simple program.now i'm going to apply it to my original code.
            thanks again πŸ‘
              You're welcome!
                sachi
                thank you very much for the detailed explanation TIG. It cleared the doubted areas about the layers.
