Add entities to a layer
Dear all,
i want to control the visibility of several components in my model. to do that i add a new layer to the model. now i want to assign those components to newly added layer(new_layer). how could i assign those components to the new layer?
theoretically there should be something like
new_layer.add component_entity
help me.thanks in advance -
The work flow is more like:
layer = Sketchup.active_model.layers.add "My New Layer" component_entity.layer=layerhttp://www.sketchup.com/intl/en/developer/docs/ourdoc/drawingelement#layer=
Good luck!
As Chris says...
You add anentityinto anentities'collection'.
Likemodel.entities,group.entities,definition.entitiesetc.
An entity can then be assigned a layer:entity.layer=my_layer
It's advisable NOT to assign layers to 'raw geometry.'
This will lead to confusion...Assigning a
.layer=is the same as you do to assign a.material=,.hidden=[true/false] and so on.
Layers are used to control objects' visibility, not to separate geometry - that separation is done using a 'container' like a group or definition, the container can then have a layer assigned too... -
thank you very much.it worked.i tested it for a simple program.now i'm going to apply it to my original code.
thanks again
You're welcome!
thank you very much for the detailed explanation TIG. It cleared the doubted areas about the layers.
