Selective component explode
i get partial succes, or it takes a very long time for the computer to process this code:
<span class="syntaxdefault">model </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model </span><span class="syntaxcomment"># Open model<br /></span><span class="syntaxdefault">entities </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities </span><span class="syntaxcomment"># All entities in model<br /></span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br /></span><span class="syntaxkeyword">for </span><span class="syntaxdefault">e in entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br /> </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">? </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance </span><span class="syntaxkeyword">and </span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"KLC2-"<br /> </span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode<br /> end<br />end</span>the model contains 43 component definitions and 976 instances.
Do you find it normal?
Is there a another way to write the code to speed the process?
@chris fullmer said:
Well, what do you mean by "a very long time"? Is it a second, or is it 2 hours?
about 3 or 4 minuts
i tried your solution, and it is also about 3 or 4 minuts
i'll be patient...thank you for the idea
Wow, that seems long. Can you uploade the model to play around with? Are the components very complex inside (their inner geometry?).
Maybe you make an array of components that you want to explode and then explode them all at once?
Ahh, that gives me an idea. Wrap the code inside of a
model.start_operation("Selective Exploder", true) ---code to explde goes here--- model.commit_operationPutting it inside the start/commit operation will make SketchUp evaluate it as a single undo. And make sure to use the True parameter in the start_operation method, which will force the UI to not refresh, and in theory could totally speed it up.
http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#start_operation
Try that and let us know how it goes,
Chris
I'd approach it differently...
n='KLC2-';m=Sketchup.active_model;m.start_operation('x',true);m.definitions[n].instances.each{|i|i.explode};m.commit_operation;This one-liner, copy/pasted+<enter> in the Ruby Console explodes all instances of the component definition that is named 'n', it's one step undo-able... It will explode locked instances too - to avoid that use
i.explode unless i.locked?instead... If there is no matching definition named 'n' you get an error message... It ignores all other definitions and instances so will be as quick as it can.
When exploding a container the length of time it takes depends on the number of objects in it AND in its context, since Sketchup has to decide about intersections etc with all of them mixed together... -
There is a faster way though. You do not need to iterate over every entity in the model, you are only interested in the components and groups. So for that, there is:
<span class="syntaxdefault">model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />defs </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />for e in defs<br />for f in e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances<br />puts f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />if f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance and f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Component#4"<br /></span><span class="syntaxdefault">f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode<br />end<br />end<br />end</span>I'm not sure that actually works perfectly, so you'll need to verify that it does. But that is the general idea.
How much geometry are we talking about? Explode is very slow. Adding geometry in SketchUp slows down as more geometry is added to the context you add to. Every time SketchUp performs intersections and splits edges and faces etc.
@glro said:
e.definition.name=="**KLC2-**"Is "
**KLC2-**" a prefix that appears at the beginning of several definition names ??If so your logical test needs to use a regular expression, thus:
if e.definition.name =~ /\A(KLC2\-)/... which returns
nilif there is no match, (and evals tofalse,) ... or if there is a match, it returns the zero based index of the match (which evals astrue.)The pattern
\Amatches the at the beginning of the string only, so in this case the only valid index position that can be returned (for a match,) is0.
ChrisSorry for the delay
here is the model
the component to explode is named KLC1-
it contains KLC1 (that's why i need to explode it)
i tried the code you suggested
it doesn't help on my computer (it freezes the computer)
exploding components seems to be a dangerous pratice in sketchup
i.explode unless i.locked?instead... If there is no matching definition named 'n' you get an error message... It ignores all other definitions and instances so will be as quick as it can.When exploding a container the length of time it takes depends on the number of objects in it AND in its context, since Sketchup has to decide about intersections etc with all of them mixed together...
i copy/pasted the code.
It seemed to give a result, lines were scrolling in the ruby window
but it never ended, i had to force sketchup to stopmaybe i got something wrong somewhere...
thank you anyway for trying
the component name in the example is KLC1-, it is not a prefix; just to make the difference with KLC1; the component embedded in it
Make a small SKP with a few components in it - one named 'KLC2-'.
Then run my one-liner [with any typos corrected - original is now fixed!].
It should not go into a loop...
Report Console errors, if any... -
this is what i typed in the ruby console
n='KLC1-';m=Sketchup.active_model;m.start_operation('x',true);m.definitions[n].instances.each{|i|i.explode};m.commit_operation;it does make a loop...
this a shot of the ruby console, but it never ended, i had to force sketchup out
What does
m.definitions[n]return assuming you define 'n' and 'm' as partial code beforehand... -
The model you provided, is that the whole model that you are working with or just a portion? The first code I posted completed in 2 seconds on that model, so I'm hoping that is only a small portion of a much larger model?
Works fine for me too, and explodes all 122 instances in a few seconds, using my code !
Geo - make certain the Outliner window is closed, and try again. Then disable that SketchStruct plugin and try again.
no, it is the whole model
the problem must be with my computer
i shall try to find out
Ahh, that's good to know! Definitely try disabling other plugins like Jim mentions.
you solved my problem !
I deleted sketchtruct and both TIG and Chris did the job in a few seconds...
How did you guess it was coming from sketchtruct?
This shows how much your "plugins quarantine" idea may help to solve plugin problems...
Thank you
Great job Jim!
Register LoginAdvertisement
