    Selective component explode
    22 Posts 6 Posters 5.5k Views 6 Watching
    • Chris FullmerC
      Well, what do you mean by "a very long time"? Is it a second, or is it 2 hours?
      There is a faster way though. You do not need to iterate over every entity in the model, you are only interested in the components and groups. So for that, there is:
      <span class="syntaxdefault">model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />defs </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />for e in defs<br />for f in e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances<br />puts f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />if f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance and f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Component#4"<br /></span><span class="syntaxdefault">f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode<br />end<br />end<br />end</span>
      I'm not sure that actually works perfectly, so you'll need to verify that it does. But that is the general idea.
        How much geometry are we talking about? Explode is very slow. Adding geometry in SketchUp slows down as more geometry is added to the context you add to. Every time SketchUp performs intersections and splits edges and faces etc.
        • Dan RathbunD
          Dan Rathbun
          @glro said:
          e.definition.name=="**KLC2-**"
          Is " **KLC2-**" a prefix that appears at the beginning of several definition names ??
          If so your logical test needs to use a regular expression, thus:
          if e.definition.name =~ /\A(KLC2\-)/
          ... which returns nil if there is no match, (and evals to false,) ... or if there is a match, it returns the zero based index of the match (which evals as true.)
          The pattern \A matches the at the beginning of the string only, so in this case the only valid index position that can be returned (for a match,) is 0.
          I'm not here much anymore.
          • G
            glro
            @chris fullmer said:
            Try that and let us know how it goes,
            Sorry for the delay
            here is the model
            the component to explode is named KLC1-
            it contains KLC1 (that's why i need to explode it)
            i tried the code you suggested
            it doesn't help on my computer (it freezes the computer)
            exploding components seems to be a dangerous pratice in sketchup
            selective component explosion
            • G
              glro
              @tig said:
              I'd approach it differently...
              n='KLC2-';m=Sketchup.active_model;m.start_operation('x',true);m.definitions[n].instances.each{|i|i.explode};m.commit_operation;
              This one-liner, copy/pasted+<enter> in the Ruby Console explodes all instances of the component definition that is named 'n', it's one step undo-able... It will explode locked instances too - to avoid that use i.explode unless i.locked? instead... If there is no matching definition named 'n' you get an error message... It ignores all other definitions and instances so will be as quick as it can.
              When exploding a container the length of time it takes depends on the number of objects in it AND in its context, since Sketchup has to decide about intersections etc with all of them mixed together...
              i copy/pasted the code.
              It seemed to give a result, lines were scrolling in the ruby window
              but it never ended, i had to force sketchup to stop
              maybe i got something wrong somewhere...
              thank you anyway for trying
              • G
                glro
                the component name in the example is KLC1-, it is not a prefix; just to make the difference with KLC1; the component embedded in it
                  Make a small SKP with a few components in it - one named 'KLC2-'.
                  Then run my one-liner [with any typos corrected - original is now fixed!].
                  It should not go into a loop...
                  Report Console errors, if any...
                  • G
                    glro
                    this is what i typed in the ruby console
                    n='KLC1-';m=Sketchup.active_model;m.start_operation('x',true);m.definitions[n].instances.each{|i|i.explode};m.commit_operation;
                    it does make a loop...
                    this a shot of the ruby console, but it never ended, i had to force sketchup out
                    loop
                      What does m.definitions[n] return assuming you define 'n' and 'm' as partial code beforehand...
                      • Chris FullmerC
                        The model you provided, is that the whole model that you are working with or just a portion? The first code I posted completed in 2 seconds on that model, so I'm hoping that is only a small portion of a much larger model?
                          Works fine for me too, and explodes all 122 instances in a few seconds, using my code !
                            Jim
                            Geo - make certain the Outliner window is closed, and try again. Then disable that SketchStruct plugin and try again.
                            • G
                              glro
                              no, it is the whole model
                              the problem must be with my computer
                              i shall try to find out
                              • Chris FullmerC
                                Ahh, that's good to know! Definitely try disabling other plugins like Jim mentions.
                                • G
                                  glro
                                  you solved my problem !
                                  I deleted sketchtruct and both TIG and Chris did the job in a few seconds...
                                  How did you guess it was coming from sketchtruct?
                                  This shows how much your "plugins quarantine" idea may help to solve plugin problems...
                                  Thank you
                                  • Chris FullmerC
                                    Great job Jim!
                                      http://4.bp.blogspot.com/_mFh2uV7t6RQ/S2e_ndxZJNI/AAAAAAAAAF8/SSwefPIDSbw/s320/sherlock-holmes-mind.jpg
                                        Jim
                                        Lucky guess, but the Ruby Console gave a bug hint...
