    Reducing thickness
    Scheduled Pinned Locked Moved Organic Modelling
    2 Posts 2 Posters 8.1k Views 2 Watching
      MadPax
      Hello there,
      Imagine I have a simple rail group extruded from a curved double bezier closed on both ends with an arc.
      Later on during the design of the model this rail is inserted into I decide that the thickness of this rail is no adequate and I want to make it thinner.
      What would be the best way to go about it?
      I tried the default offset tool inwards and then finish the lines to make a new face and then I de-extrude the excess thickness but this method seems so cumbersome and I suspect it can't be used everywhere or in every situation.
      Any ideas?
      Thanks,
      Peter
      • panixiaP Offline
        panixia
        as far as i know the better method is using some curviloft/tig estrusion tools, depending on the shape, making sure to keep the original geometry instead of deleting it, so that if you need further tweaking/editing you can redraw the thing quite fast. i find in this case is much easier to redrav than rscale/fix/cleanup etc..
