    [Plugin] Key Scene v1.0.3
    22 Posts 6 Posters 17.1k Views 6 Watching
    • renderizaR Offline
      renderiza
      [pre:279b0oxk]Author:: Renderiza
      Plugin Name:: Key Scene
      Version:: 1.0.3
      Date:: 8/29/2013
      Cost:: Free[/pre:279b0oxk]
      Old version video: (Outdated!)
      http://www.youtube.com/watch?v=jZcK-SYRFJg%26amp;feature=plcp
      Key Scene
      %(#909090)[Key Scene enables you to customize your scenes to be navigated with your keyboard.
      This plugin was completely redone and now have user friendly web-dialog to customize which keyboard shortcut activates what scene...enjoy!]
      http://s18.postimg.org/q2lvs6tnt/icon.jpg
      Available at
      sketchUcation
      pluginStore
      click here
      ______________________________________________________________________
      Extension Warehouse
      click here
      Note: If the latest version is not yet available at Extension Warehouse that means it is still awaiting to be approved by the quality assurance team to make sure extension meets the technical and security requirements.
      Download Practice SketchUp File
      Web-Dialog
      http://s11.postimg.org/4zjzzf7pf/key_dialog.jpg
      Recommended Plugins :
      SketchUp Window Settingsby Anton_S- Activate full-screen mode inside SketchUp.
      SimFonIA Animation Toolsby SimFonIA_team- All the animations for Key Scene demo video were made with SimFonIA Animation Tools.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Aerilius
        That is absolutely stunning!
        You give us a lot of new fresh ideas, thanks! (I especially find the character out of spheres very cool)
        I believe we will see much more cool things like this when SketchUp gives us view.draw_image(). I'm just checking out the code, how you drew the images and menus...
          Cool one! β˜€ and music! 😎
          If I good understand it's a sort of launcher existing animations, or display scenes ?
            renderiza
            Thanks for your comments!
            Aerilius - I also hope the Sketchup API is expanded with new possibilities. By the way just in case anyone is interested the background images can be modified with the Watermark Settings in the style options.
            Pilou - In my case it sort of was showcasing animations but that doesn't have to be the main purpose. I hope people find unique ideas on how to implement this script into their presentations.
              Anton_S
              Pretty nice concept! πŸ‘
                renderiza
                Anton_s - Hey thanks for your comment and also for your awesome plugin "SU Window Settings 2.0.0"!
                  driven
                  Note: At the moment the plugin is not portable but soon with thomthom is suggestion I will work towards that.
                  I've got 'most' the functionality, but there's a few stumbling blocks before it will work better on a mac,
                  I can easily go 'full screen' except for SU's 'footer bar' and apples [side] background embellishment.
                  SU can hide the 'Custom Toolbar', 'Dialogs' and the 'Scene Tabs', I can close any others.
                  I was geting lots of crashes so I checked the skp...
                  [Watermarks can cause issues on macs.]
                  when I open the KeyScene-1.skp [independently], it crashes SU when I get to pages with 2 Watermarks, if I remove all the 'SpaceBar' WM it will run as a slide show ok.
                  after that, in 'Key Scene' html
                  if I disable all the sound, I get no hangs or crashes although I 'still' get a system sound [for bad keystroke] whenever the dialog is focused.
                  I can navigate the Menu's if I wait and or click twice. It's a bit 'clunky' and sometimes a reset is required.
                  I can go 'back' if I change ESCAPE to HOME [Esc always closes the Dialog on mac]
                  I can view the the videos if I add "file://" to the path, and use VLC player to run, [DivX crashes the mac]
                  Modifying a group seemed to stop things working?
                  It maxes out the CPU unless paused...
                    renderiza
                    Thanks driven for going to all that trouble to try and make the plugin work on a mac. Me not having a mac to test this issues is definitely frustrating. For the 'full screen' plugin I am sure Anton_S will be happy to help you out.
                    I will change the double watermarks on one style and merge them together to solve the crash issues.
                    I suspect that what is making the plugin 'clunky' is the sound...since in order to go to the next frame the sound needs to load. I though I solved this by using .swf to reduce the size as much as possible but I guess it is still giving problems. Or maybe is not that at all and is another thing.
                    Maybe there is a way to detect if user is on a mac to make an if statement an choose the 'HOME' key instead of the 'ESC' key...I will need to check on that.
                    I guess this is why thomthom told me to learn how to call the files using the magic constant FILE. I am kinda lost at the moment on how to switch to that but I just need to study it a little bit more.
                    Not sure if when you try to modify a group you are not refocusing the web dialog since that needs to be selected for the plugin to work.
                    Yeah the next frame is constantly being called couple of times a seconds so I imaging its using quite a lot of CPU power. Maybe I can learn a more efficient way of handling frames when its not needed to be updated.
                    Thanks again for letting me know this issues it means a lot πŸ˜„
                    NOTE: I uploaded a new skp file with the watermarks merged. Hope I can solve the next issues πŸ˜•
                      renderiza
                      You said that sometimes you needed to double click 'ENTER' to go to next menu and in occasions needing to reset for it to work and I think I might know why is this...When you hit 'Play' the button can't be focused because when you keep hitting enter its like you are re-hitting 'PLAY' which causes the timer to speed-up making the plugin not work if you keep hitting enter.
                      I solved this in my computer at least when adding the following code to start every time you hit 'Play'.
                      window.focus()
                      But maybe since you are using a Mac it is possible the Web Dialog isn't un-focusing the 'Play' button when you hit it.
                      If this is the case then I might want to consider not using the 'ENTER' key but rather the 'Spacebar' not sure. Anyways try manually un-focusing the 'Play' button and see if that solves the problem to be sure it is that in the first place.
                      Cheers!
                        driven
                        The new .skp, avoids those crashes,
                        have you got a version completely devoid of sound, and any timer functions just for it.
                        maybe I missed something, and that's slowing it down.
                        also, SU has to finish it's moves before the next action runs, but it's not queued so you need to re-hit if you hit to early.
                        I'm having a look on and of while doing something else, but may get more time later
                        john
                        edit: I always get this as well, dosen't seem to effect things terminally, but may slow it down
                        Error: #<NoMethodError: undefined methoddefinition' for #Sketchup::Edge:0x17bfc8d8>
                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:625:in push_frame' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:624:in each'
                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:624:in push_frame' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:36:in initialize'
                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:625:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/keyscene.rb:625
                        maybe this shows the delay?
                          renderiza
                          I have uploaded a version with no sounds called keyscene_nosound.rbz
                          Does errors don't look good and I have no clue right now how to fix them but I'll keep an eye on them. Thank you for helping me figure this one out I really appreciate it.
                            Anton_S
                            The error raises because the sub-entities are not only groups and components, but also edges, faces, and points. To avoid the error, simply add
                            next unless [Sketchup::Group, Sketchup::ComponentInstance.include?(subentity.class)]
                            In the line 624
                            It should look like this
                              renderiza
                              Wow! Very nice to know...Thank you very much!
                              • CadFatherC Offline
                                CadFather
                                can't believe i never saw this plugin before - did you do the music as well, Rafael?
                                  renderiza
                                  Yes I did the music on both animations featured in the video. I have a small play list of other music I have done as well. http://www.youtube.com/playlist?list=PLFGYnoQXuwjAwqBgUX1DSHAfBco0dzcKZ
                                  Cheers!
                                    CadFather
                                    wow.. amazing... 'sad good bye' sounds like Renderiza's late quartets...great atmosphere!
                                      renderiza
                                      Thank you! that compliment makes me wanna do music again! πŸ’š
                                        CadFather
                                        playing in a band is how i ended up in england, did it for 10 years and then completely gave up for another 10. then...last september i had a dream. i was chasing a thief, when suddenly i hear someone calling my name... i look up, and who do i see on the window calling me... but the master himself... BBKing!!! πŸ˜† he threw me a sack, i caught it, opened it up and found it full of old cassettes.... my life was never the same! β˜€
                                        well i did dig out my old guitar, and started playing again after so many years.. not sure what mr. freud would say, but i'm enjoying every bit of it - without added sugar! 😎
                                          renderiza
                                          New version of Key Scene is now available!
                                          Because of the file size it may take a while when downloading through Plugin Store.
                                          The main changes in this version are:
                                          • Key Scene is now a SketchUp Extension.
                                          • Some speed improvement were done thanks to Anton_S
                                          Note: Because of the file size I removed the Videos but if you want to include the videos place them on RND_KeyScene > KeySceneFiles > video1.avi
                                            renderiza
                                            New video tutorial is up! (Recommend watching it in HD)
                                            Any questions or feedback is welcome.
                                            • 1 / 2
