    How to PushPull along angled, curved path?
    8 Posts 4 Posters 2.9k Views 4 Watching
    • marked001M Offline
      marked001
      I'm horrible with keeping up with plugins, etc.. so I'm hoping you guys can help me out. I've got this base moulding here that is 'supposed' to curve around this corner while angling up the stairs. Obviously if I use Follow Me it splays out as it goes up and around the corner. Any thoughts? Hopefully this is an easy one! Thanks.
      http://www.revision21vis.com
      instagram: revi21on
      • gillesG Offline
        gilles
        follow me and keep.
        see plugins index
          marked001
          Thanks! Not coming out perfectly.. but its close enough. Appreciate the quick reply.
          instagram: revi21on
          • pbacotP Offline
            How do you get that path that is tangent to both edges?
              marked001
              talking about the path in my image, peter?
              I just intersected an angled plan to get the path. Which I think is the cause of the problems.. all of those tiny segments were messing up the extrusion. Thanks.
              instagram: revi21on
              • boofredlayB Offline
                boofredlay
                Jason, I highly recommend Profile Builder.
                There is a free version here:
                http://sketchucation.com/forums/viewtopic.php?f=323&t=44237&hilit=profile+builder
                Or the Pro version here:
                http://www.smustard.com/script/ProfileBuilder
                A quick example:
                Edit:
                I tried one with a curved path like you have and it twisted. Maybe follow me and keep would be better in this application.
                • pbacotP Offline
                  Yes, I mean the curved path between the straight runs. Thanks for the geometry lesson! I was making it more complicated than necessary.
                  • pbacotP Offline
                    FMAK is pretty awesome, and it works alright, but I guess a lot of small segments are a pain.
                    Actually the profile should run perpendicular to path. FMAK is probably an OK fake in such a case. Extrude edges by rails is more accurate. When I did it it looked good, and the profile was the correct cross section as it continues up the stairs.
                    [EDIT: I made two paths based on two planes. There was a minute misalignment with the stair wall, which was fixable, and may be due to operator error, making the paths.]
                    EEbyR
                    In the end. what do you use? A Flexi-molding which is of course not geometrically perfect either.
