    [Plugin] Stepped Extrude [Updated 20121106]
    28 Posts 18 Posters 34.6k Views 18 Watching
    • I
      icepam
      Thanks for a much useful plugin. I had coded something similar in AutoLisp a few years ago to do this in Autocad, precisely for stairs and contours.
      @rami_lpm said:
      @pbacot said:
      ... interpret the height of contours in plan by the user drawing a section line.
      This sounds very complicated, I'll see what I can do.
      I think this could be simpler than it sounds, maybe one of the forum's rubymasters could help out with the code. Here's how i would imagine it:
      Method 1, should work with lines:
      -User draws a line across the contours he wishes to raise and sets H=riser height.
      -Plugin figures if it's a generally horizontal or vertical line (is that necessary?)
      -Plugin finds all intersection points and makes an array ordered based on their X (or Y?) coordinate
      -Plugin traverses array raising each line by H x its index in the array.
      Method 2, perhaps this is the solution for faces?
      -User selects all faces that need to be raised (by window or select all or whatever... if one by one, it's just the current method)
      -User draws a line L through all said faces
      -Plugin filters out non-faces from selection and makes an array as above, ordered by X or Y coordinate of mid-point of segment created by intersection between line L and each face.
      -Plugin traverses and raises as above.
      Hope this makes sense!
        No possibility to add the other options? As asked in my old request here πŸ˜‰
        Now we have a =a + x πŸ˜‰
        http://sketchucation.com/forums/download/file.php?id=83670
        • C
          caronte01
          Great simple tool, perfect for stairs. Will try it as soon as I have a chance!
          Thanks!
          santiago
          • rami_lpmR
            rami_lpm
            icepam: I'm a bit math-challenged, so it will take some time.
            pilou: It really should work with lines. About your request, what does the 'list' option do?
            Thanks everyone for the comments
              Like in this Multiple Offsets by Sdmitch πŸ˜‰
              You enter a list in a dialog box like 5,17,22,10 etc...
              At each click the PushPush take a nomber in the list
              so first click is 5
              second click 17
              etc...
              and then after the 10 that will be the 5
              etc...
              PS You can also have a random option one in a list given or out of a list (Mini-maxi)! πŸ˜‰
              here the list was 10,20,30,50* (the * indicated the last number)
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
              • qingtongQ
                qingtong
                thanks very much!
                • greenskpG
                  greenskp
                  Thank you very much rami_lpm. Very usefull and saved my life in actual job.
                  It's possible that commit_operation undo all steps instead one by one?
                  • E
                    Emad12
                    • 2 / 2
