    [Plugin] Stepped Extrude [Updated 20121106]
    28 Posts 18 Posters 34.9k Views 18 Watching
    • bsintzelB
      bsintzel
      Simple, functional, useful and free...what more can one ask for. Well done πŸ‘
      I've taken obfuscating to a whole new level!
        rv1974
        The perfect fuse of simplicity and effectiveness.
        Salute to the authors.
        • I
          icepam
          Thanks for a much useful plugin. I had coded something similar in AutoLisp a few years ago to do this in Autocad, precisely for stairs and contours.
          @rami_lpm said:
          @pbacot said:
          ... interpret the height of contours in plan by the user drawing a section line.
          This sounds very complicated, I'll see what I can do.
          I think this could be simpler than it sounds, maybe one of the forum's rubymasters could help out with the code. Here's how i would imagine it:
          Method 1, should work with lines:
          -User draws a line across the contours he wishes to raise and sets H=riser height.
          -Plugin figures if it's a generally horizontal or vertical line (is that necessary?)
          -Plugin finds all intersection points and makes an array ordered based on their X (or Y?) coordinate
          -Plugin traverses array raising each line by H x its index in the array.
          Method 2, perhaps this is the solution for faces?
          -User selects all faces that need to be raised (by window or select all or whatever... if one by one, it's just the current method)
          -User draws a line L through all said faces
          -Plugin filters out non-faces from selection and makes an array as above, ordered by X or Y coordinate of mid-point of segment created by intersection between line L and each face.
          -Plugin traverses and raises as above.
          Hope this makes sense!
            No possibility to add the other options? As asked in my old request here πŸ˜‰
            Now we have a =a + x πŸ˜‰
            http://sketchucation.com/forums/download/file.php?id=83670
            • C
              caronte01
              Great simple tool, perfect for stairs. Will try it as soon as I have a chance!
              santiago
              • rami_lpmR
                rami_lpm
                icepam: I'm a bit math-challenged, so it will take some time.
                pilou: It really should work with lines. About your request, what does the 'list' option do?
                Thanks everyone for the comments
                  Like in this Multiple Offsets by Sdmitch πŸ˜‰
                  You enter a list in a dialog box like 5,17,22,10 etc...
                  At each click the PushPush take a nomber in the list
                  so first click is 5
                  second click 17
                  etc...
                  and then after the 10 that will be the 5
                  etc...
                  PS You can also have a random option one in a list given or out of a list (Mini-maxi)! πŸ˜‰
                  here the list was 10,20,30,50* (the * indicated the last number)
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
                  • qingtongQ
                    qingtong
                    thanks very much!
                    • greenskpG
                      greenskp
                      Thank you very much rami_lpm. Very usefull and saved my life in actual job.
                      It's possible that commit_operation undo all steps instead one by one?
                      • E
                        Emad12
                        • 2 / 2
