    [Plugin] Stepped Extrude [Updated 20121106]
    28 Posts 18 Posters 34.1k Views 18 Watching
    • pbacotP Offline
      Pilou, The first post claims this is possible. I haven't tried. Peter
        No it's draw also a face when you click a line like when you click on a face! πŸ˜‰
        I just want stepp the lines ! πŸ˜„
        • sumasterS Offline
          sumaster
          Hi rami_lpm AND sdmitch,
          a Need of previous history Amount/Distance . . . .
          means create 2 face and use this tool and 1st face extrude 1 m. and 2nd face extrude the same amount . . .
          now its not working . . . . .
          thanks . . . .
          Thank you,
          SUmaster
          • bsintzelB Offline
            bsintzel
            Simple, functional, useful and free...what more can one ask for. Well done πŸ‘
            I've taken obfuscating to a whole new level!
              rv1974
              The perfect fuse of simplicity and effectiveness.
              Salute to the authors.
              • I Offline
                icepam
                Thanks for a much useful plugin. I had coded something similar in AutoLisp a few years ago to do this in Autocad, precisely for stairs and contours.
                @rami_lpm said:
                @pbacot said:
                ... interpret the height of contours in plan by the user drawing a section line.
                This sounds very complicated, I'll see what I can do.
                I think this could be simpler than it sounds, maybe one of the forum's rubymasters could help out with the code. Here's how i would imagine it:
                Method 1, should work with lines:
                -User draws a line across the contours he wishes to raise and sets H=riser height.
                -Plugin figures if it's a generally horizontal or vertical line (is that necessary?)
                -Plugin finds all intersection points and makes an array ordered based on their X (or Y?) coordinate
                -Plugin traverses array raising each line by H x its index in the array.
                Method 2, perhaps this is the solution for faces?
                -User selects all faces that need to be raised (by window or select all or whatever... if one by one, it's just the current method)
                -User draws a line L through all said faces
                -Plugin filters out non-faces from selection and makes an array as above, ordered by X or Y coordinate of mid-point of segment created by intersection between line L and each face.
                -Plugin traverses and raises as above.
                Hope this makes sense!
                  No possibility to add the other options? As asked in my old request here πŸ˜‰
                  Now we have a =a + x πŸ˜‰
                  http://sketchucation.com/forums/download/file.php?id=83670
                    caronte01
                    Great simple tool, perfect for stairs. Will try it as soon as I have a chance!
                    santiago
                    • rami_lpmR Offline
                      rami_lpm
                      icepam: I'm a bit math-challenged, so it will take some time.
                      pilou: It really should work with lines. About your request, what does the 'list' option do?
                      Thanks everyone for the comments
                        Like in this Multiple Offsets by Sdmitch πŸ˜‰
                        You enter a list in a dialog box like 5,17,22,10 etc...
                        At each click the PushPush take a nomber in the list
                        so first click is 5
                        second click 17
                        etc...
                        and then after the 10 that will be the 5
                        etc...
                        PS You can also have a random option one in a list given or out of a list (Mini-maxi)! πŸ˜‰
                        here the list was 10,20,30,50* (the * indicated the last number)
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
                        • qingtongQ Offline
                          qingtong
                          thanks very much!
                          • greenskpG Offline
                            greenskp
                            Thank you very much rami_lpm. Very usefull and saved my life in actual job.
                            It's possible that commit_operation undo all steps instead one by one?
                            • E Offline
                              Emad12
                              • 2 / 2
