    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 17.2k Views 6 Watching
      @driven said:
      the puts should read [0, 50, 100, 150, 200, 250] "2撖죺"
      Where are these numbers from?
      Why are you expecting a NULL byte? (That's usually a string termination in C.)
        driven
        I think this may be the root of my issues
        if you unpack(C), then pack(U) sh*t happens
        > a = "2撖죺".unpack('C*') b = a.pack('U*') c = puts a.inspect puts b.inspect [50, 230, 146, 150, 236, 163, 186] "2撖죺" nil
        and visa-versa
        > a = "2撖죺".unpack('U*') b = a.pack('C*') c = puts a.inspect puts b.inspect [50, 25750, 51450] "2\226\372" nil
        I think the first is happening somewhere
          driven
          font = Arial Unicode MS
          SU Top again
          WD bottom
          look familiar
            driven
            Pack and unpack bytes to strings
            I need to write a function that "packs" an array of bytes (integers between 0 and 255) into a string. I also need to be able to perform the reverse operation, to get my byte array from the string t...
            Code Review Stack Exchange (codereview.stackexchange.com)
              That's from a questions that doesn't really make sense.
              Also:
              Seeing as JavaScript has 16-bit strings, I packed two bytes per character.
              Two byte per character isn't UTF-8.
                driven
                I was looking for test code and only grabbed the example, I got there from the Stackoverflow 'fix' that referred back.
                Do these work as 3D Text on the PC...
                I ran the full gamete of unpack().pack() scenario's in console and a mismatch is the only way to get the same results as the straight input.
                john
                • Dan RathbunD Offline
                  Dan Rathbun
                  @thomthom said:
                  fonts.sort! %(#008000)[# (!) Not UTF-8 compatible! But better than nothing.]
                  (1) Since this will run only on Mac, which is Unicode aware, can't you pass the list to a command shell and use the shell's built-in sort filter ??
                  For instance on WIN, in DOS command shell, you can filter output by piping it through the sort filter, thus:
                  doc_list = %x(dir "~/documents/myproject" | sort)
                  or similar.
                  You'd need to build a plain text list from the array, each element being a line, separated by " \n"
                  (2) Alternative ... build an array copy using pack, sort it, then & unpack back to strings.
                  I think I'm late posting this... you guys are posting machines!
                  I'm not here much anymore.
                    If there is such a command then I'd guess that would work. But I'm not familiar with OSX terminal. Maybe John knows?
                    I can also use JS to sort it - since I'm displaying the list in a WebDialog.
                      Dan Rathbun
                      Shell Scripting Primer: Command Line Primer
                      tcsh(1) OS X Manual Page[*]
                      Filename substitution
                      If a word contains any of the characters *`', ?', `` [' or {`' or begins with the character ~`' it is a candidate for filename substitution, also known as globbing''. This word is then regarded as a pattern (glob-pattern''), and replaced with an alphabetically sorted list of file names which match the pattern.
                      • Also do a Find on " ls-F", it is a built-in and supposed to be faster than " ls -F"
                      OS X Manual Page: ls command Reference
                        driven
                        This is probably my last effort on this.... circles,
                        but, I finally figured out find in Ruby Console, escapes, escapes, escapes...
                        THE THIRD WAY... no Font Book... no fc-list... just plain old find >> mdls... not the fastest, but not too bad.
                        inculed is Dan's tester, these all created 3D text from console, only Font Book and usr/local/bin/fc-list do that out of the can.
                        a=(`find /System/Library/Fonts\ /Library/Fonts\ ~/Library/Fonts\ \\( -name "*.ttf" -o -name "*.otf" \\) -type f`).split("\n").map! { |f| f.gsub(" ", "\\ ")} #need this or something to catch spaces in filenames
                        b=(a.collect{|x| `mdls  -name com_apple_ats_name_family -raw #{x}`}).map! { |f| f.split(",")[0]} #the other items in each array are unicode strings for other languages, if you want those use Font Book
                        c=b.map { |f| f[/[("\s]+([^"\n]+)[)"\s]+/m,1] }.uniq!.sort![2..-1] #[0] is empty, [1] is a dot file, could remove them
                        macFonts = c
                        chunksize = 1
                        chunk = 1
                        limit = macFonts.length
                        model = Sketchup.active_model
                        fsize = 1.0
                        linespacing = 1.2
                        bold = false
                        italic = false
                        thick = 0.05
                        filled = true
                        quality = 0.0
                        i = 0
                        while i < limit
                          begin
                            model.start_operation("3D Fontnames (#{chunk})")
                              chunksize.times do |n|
                                break if i == limit
                                item = macFonts[i]
                                grp = model.entities.add_group()
                                grp.entities.add_3d_text( "#{item}", TextAlignCenter, "#{item}",
                                  bold, italic, fsize, quality, 0.0, filled, thick )
                                grp.name= item
                                grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-(i*linespacing),0)) )
                                i += 1
                              end # chunk
                            model.commit_operation()
                          rescue Exception => e
                            puts("\n*** macFonts group Error! ***")
                            puts("  i = #{i}")
                            puts("  chunk = #{chunk}")
                            puts("  font = #{macFonts[i]}\n")
                            model.abort_operation()
                            puts("Error #<#{e.class.name}; #{e.message}>")
                            puts(e.backtrace) if $VERBOSE
                            raise
                          chunk += 1
                        end # while
                        • 6
                        • 6 / 6
