    White Walls
    extensions
    1 Posts 1 Posters 276 Views 1 Watching
    • Al HartA
      Al Hart
      We sent out a rendering tip today about White Walls.
      Boothy pointed out that you can also make quick adjustments to walls using the Material/Color channels feature.
      Here is a rendering of a house which we used for our first Webinar;
      http://wiki.renderplus.com/images/e/ef/Webinar_house1.jpg
      By clicking on the material in the back wall, you can select Change Color
      http://wiki.renderplus.com/images/a/ae/Change_color.jpg
      This brings up a Wizard which lets you make changes to the color of a material after rendering.
      Here I changed it to HSL (rather than RGB) mode, which lets you set the luminance of the color directly. And used the slider bar to move it more towards white.
      http://wiki.renderplus.com/images/8/8c/Changl-color2.jpg
      I was able to adjust the wall with the slider until I got a lighter effect.
      Note Material Channels does not re-render the model, so if you change the color too much, any anti-aliasing at the edge of the color will not be changed properly, and also any reflections of a color will not be changed. But it can be a good idea for Walls.
      See: Material Channels
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
