    Beware of windows 8
    24 Posts 9 Posters 3.9k Views 9 Watching
    • silverwingsltdS Offline
      silverwingsltd
      I've just installed windows 8 on my cpu and to my great disappointment, sketchup was suddenly working very slow compared to windows 7
      Has anyone got the same problem? or know what to do?
      imac Windows 8 Intel Core i7-2600 CPU 3.40GHz 12GB RAM
      IntelCore i7-2600 CPU @ 3.40GHz 12.0 GB RAM Sketchup 8 VfSU 1.6 beta
        CPU?
        Anyways, Pete (solo) runs SU on Win 8 and he says it's fine. You say you have an iMac. Are you sure it's not due to some incompatibility?
          Aerilius
          Like with any fresh new graphics card (= or new operating system version that needs its own drivers), you have to leave some time until the drivers are optimized.
          • soloS Offline
            solo
            @silverwingsltd said:
            I do not think it's possible to install software on a CPU, hard drive another story.
            I have been running Windows 8 for 6 months (preview version, now full install) and everything runs great, all drivers are stable, in fact even Nvidia has windows 8 drivers available.
            Now regarding installing windows on an iMac...are you serious? why?
            http://www.solos-art.com
              There are reasons why Mac users run Windows via Bootcamp or Parallels once in a while. Quite a lot of applications are Windows only for instance. But probably here there is some hardware (video card) and software (driver) issue, indeed.
              • Paul RussamP Offline
                Paul Russam
                Parallels have issued a KB article asking users NOT to upgrade to Win8 until they have found/fixed some problems
                http://kb.parallels.com/114973
                Paul Russam
                English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                • andybotA Offline
                  andybot
                  is this running in a virtualized environment on top of a mac OS? If not, it does seem odd to install windows directly on mac hardware. Either way, it may indeed be a hardware support issue. πŸ˜• That's not a typical configuration... (edit: I mean installing on mac hardware directly. Of course the VM environment is used regularly.)
                  Also - why go to windows 8 on a mac? Any particular reason? Seems like win7 would work just fine if it's just to run a few windows programs.
                    Have you checked that you got proper drivers for your graphic card on Win8.
                    On my Netbook, which under Windows7 have OpenGL hardware acceleration, I found that the default drivers under Windows8 did not provide this. The manufacturer, Packard Bell, has not issued updated drivers yet. This is why I get annoyed by laptop manufacturers because they always make you use their own custom drivers - instead of using plain vanilla drivers. And they are always slow to update - or quickly stop updating them.
                    • sketch3d.deS Offline
                      sketch3d.de
                      in the meanwhile many recent nVidia GPUs are supported directly by nVidia an their plain vanilla drivers.
                      no need to use ol' manufacturer drivers or wait for them updating these.
                      I would check too, if the hardware acceleration in the OpenGL settings of SU is enabled.
                      Norbert
                      btw, running Windoze directly on an intelMac is not very uncommon, e.g. a Macbook Air/Pro is a nice piece of hardware and runs fine w/ Windows too.
                        Unfortunately my netbook has a Intel Integrated GMA 4500 card. 😞
                          sketch3d.de
                          you may want check directly by intel (GM45 chipset).
                          on the other hand, who wants to use an OpenGL based 3D modeler on a lame netbook w/ a shared and thus slow graphics 'accelerator' πŸ˜‰
                          Norbert
                            Yea - I don't do work on it. But I bring the notebook when I'm on the go - like at Basecamp. I had to boot back into Win7 for my presentations. But seeing how Win7 has OpenGL support I'd hoped that Win8 would as well.
                            • soloS Offline
                              solo
                              I used Windows 8 on my laptop at basecamp, ran Sketchup and Thea seamlessly. I have 8400M dedicated card however if that makes the difference.
                                silverwingsltd
                                Hi again
                                First of all... About the iMac vs Windows-thing:)
                                You don't get a much better picture than on an 27 inch iMac;)
                                The downside to that is that I bought my licensed Sketchup and vray back when I only had a PC, but with bootcamp and windows 7 on the mac, everything was working just fine.
                                I found the problem. It is the video card (AMD Radeon HD 6900m) that's causing trouble (or at least I think it is) anyway, I can't turn on the "use hardware acceleration" button. I have tried updating the graphics card but nothing happens... unfortunately:(
                                • soloS Offline
                                  solo
                                  Tried updating to this driver: http://drivers.softpedia.com/get/GRAPHICS-BOARD/AMD/AMD-Radeon-HD-6900-Display-Driver-8982108000-for-Windows-8.shtml
                                    sketch3d.de
                                    @solo said:
                                    ...softpedia.com...
                                    ...or download directly from AMD.
                                    Norbert
                                      ascolima
                                      Hi again
                                      Hi silverwingsltd
                                      I am having the same exact problem you describe here. My sketchUp runs super slow on my newly installed windows 8, and I'm not able to use the "hardware acceleration".
                                      Have you been able to find a solution? Please share if you did.
                                        What graphic card do you have? Have you installed and updated all your drivers?
                                          ascolima
                                          Hi, my laptop has "mobile intel 4 series express chipset family). I did update the driver to the latest for Windows 8 (WDDM 1.1). But my sketchUp is still super slow, and the open GL acceleration is still grayed-out.
                                          However, yesterday I did more research and read in a gaming forum that some of these drivers do not support Open GL yet on Windows 8. And the way to fix that was to adjust your startup to load the driver for Windows 7, and open GL should run fine like that.
                                          I have not had the guts to give that a try though. any suggestions?
                                          Here's a discussion about it:
                                          http://communities.intel.com/message/171099
                                            sketch3d.de
                                            SU does - as any other OpenGL based 3D modeler - require a fully and mature OpenGL v1.5+ support. Which shared/integrated grapics subsystems of e.g. office desktops or low-end notebooks simply do not provide.
                                            hth,
                                            Norbert
                                            • 1 / 2
