    Make Unique Texture
    7 Posts 5 Posters 707 Views 5 Watching
      spring.freediver
      Is there an API equivalent to the interactive context menu item for a face called "Make Unique Texture"?
      Also, is there a known problem with Texture Writer reducing the resolution of Textures? When we write out an OpenFlight file, we try to use the original images to create the OpenFlight rgb files. But if the original images are not available, we resort to using the Texture Writer. Our customers complain the there is a loss of resolution when we use the Texture Writer. Is there any way to control the resolution?
      • cottyC Offline
        cotty
        I think there is no API equivalent, see this statement from Aerilius.
        my SketchUp gallery
        • Dan RathbunD Offline
          Dan Rathbun
          I do not see a way specifically.
          Are you specifying a low-loss filetype such as png ?
          I'm not here much anymore.
            Dan Rathbun
            I did find this in the API. Worth a try if the material is textured.
            Material.write_thumbnail
              There is no direct API equivalent to making a unique texture.
              However, if you make a 'texturewriter' and use it to export the texture file, using the selected face.materail as the 'source', then it will retain any distorted UVmapping etc.
              Therefore, you can extract the distorted texture image file for the selected face.material to a TEMP location.
              Then you simply 'clone' [make] a new material... based exactly on the original material's spec [RBGA etc]... BUT you instead use the new texture-image file [using the original's texture size etc too]...
              So although it's not "in" the API you can readily write a 'reusable' method along these lines to make a new unique material for any selected [distorted] face...
              There is [currently] no API method to write [or read] SKM files so you will need to manually save any model materials externally, OR you can install/use my "SKMtools", which add those functionalities to the API.
              Here is a method that makes a face's material unique and returns the new material [or none is no texture].
              It is now part of my SKMtools/materials missing API methods [but it is as yet unpublished]... If you give it an optional argument 'true' the new material's texture is made as a .png format file rather than the mimicking the original's file-type...
              class Sketchup;;Face
              if not Sketchup;;Face.method_defined?(;material_make_unique)
              	def material_make_unique(png=false)
              		mat=self.material
              		return nil unless mat
              		return nil unless txt=mat.texture
              		iwi=txt.width
              		ihi=txt.height
              		### later we use ### texture.size=[w, h]
              		tads=txt.attribute_dictionaries
              		nam=mat.display_name
              		alp=mat.alpha
              		col=mat.color
              		mads=mat.attribute_dictionaries
              		mats=Sketchup.active_model.materials
              		namp=nam+"1"
              		namp.next! while mats[namp]
              		num=namp.gsub(/^#{nam}/,"")
              		nmat=mats.add(namp)		###
              		tw=Sketchup.create_texture_writer
              		tmp=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP'
              		tmp=ENV["TMPDIR"] unless tmp ### it's a MAC
              		tna=File.basename(txt.filename, ".*")+num+File.extname(txt.filename)
              		tna=File.basename(tna, ".*")+".png" if png
              		pth=File.join(tmp, tna).tr("\\","/")
              		tw.load(self, true)
                      tw.write(self, true, pth)
              		nmat.alpha=alp
              		nmat.color=col
              		mads.each{|d| d.each_pair{|k,v| nmat.set_attribute(d.name, k, v)}} if mads
              		nmat.texture=pth
              		ntxt=nmat.texture
              		ntxt.size=[iwi, ihi]
              		tads.each{|d| d.each_pair{|k,v| ntxt.set_attribute(d.name, k, v)}} if tads
              		return nmat
              end#class Face
              You are advised not to mess with a base class but it should give you enough code hints to make your own tool to do this...
                Yea, please do not mess with the base classes.
                  For the avoidance of doubt --- here's a base-class free version...
                  Please implement something like this... 😄
                  <span class="syntaxdefault"></span><span class="syntaxcomment">### pass a 'face' as the first argument<br />### and a second optional argument to convert the image texture into a PNG format<br />### it returns the new material, or 'nil' if the face is incorrect<br />### or if there's no face.material.texture...<br /></span><span class="syntaxdefault">def material_make_unique</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> png</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil unless face<br />    return nil unless face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil unless mat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />    return nil unless txt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture<br />    iwi</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">txt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">width<br />    ihi</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">txt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">height<br />    </span><span class="syntaxcomment">### later we use ### texture.size=[w, h]<br /></span><span class="syntaxdefault">    tads</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">txt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">attribute_dictionaries<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    nam</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name<br />    alp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha<br />    col</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color<br />    mads</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">attribute_dictionaries<br />    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    mats</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials<br />    namp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nam</span><span class="syntaxkeyword">+</span><span class="syntaxstring">"1"<br /></span><span class="syntaxdefault">    namp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">next</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> while mats</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">namp</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">namp</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">gsub</span><span class="syntaxkeyword">(/^</span><span class="syntaxcomment">#{nam}/,"")<br /></span><span class="syntaxdefault">    nmat</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">namp</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    tw</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">create_texture_writer<br />    tmp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ENV</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"TEMP"</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxcomment">### it's a PC == 'TEMP' or 'TMP'<br /></span><span class="syntaxdefault">    tmp</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ENV</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"TMPDIR"</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> unless tmp </span><span class="syntaxcomment">### it's a MAC<br /></span><span class="syntaxdefault">    tna</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">txt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">".*"</span><span class="syntaxkeyword">)+</span><span class="syntaxdefault">num</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">extname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">txt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    tna</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tna</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">".*"</span><span class="syntaxkeyword">)+</span><span class="syntaxstring">".png"</span><span class="syntaxdefault"> if png<br />    pth</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tmp</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> tna</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"\\"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"/"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    tw</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">load</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    tw</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> pth</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">###<br /></span><span class="syntaxdefault">    nmat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">alp<br />    nmat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">col<br />    mads</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_pair</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">k</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> nmat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> k</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> v</span><span class="syntaxkeyword">)}}</span><span class="syntaxdefault"> if mads<br />    nmat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">pth<br />    ntxt</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nmat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture<br />    ntxt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size</span><span class="syntaxkeyword">=[</span><span class="syntaxdefault">iwi</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> ihi</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    tads</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_pair</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">k</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> ntxt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> k</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> v</span><span class="syntaxkeyword">)}}</span><span class="syntaxdefault"> if tads<br />    return nmat<br />end<br /></span>
