    Dynamic Opening in Panel
    1 Posts 1 Posters 693 Views 1 Watching
    • gullfoG
      gullfo
      a simple component with a round or square (or oblong if desired) opening in a panel. you specify the component x-y-z lengths and the opening x-z and the opening offset x-z (no checking to see if the opening protrudes past the length settings).
      i'm using this for a dynamic baffle box component used to isolate ducts between rooms or main duct feeds. probably could be used for all kinds of panels where you need a round opening and want to set it dynamically as part of another component.
      the component itself is in the attached file so open it and then save the component to your component folder or explode it if you import it into a model.
      dynamic opening in panel
      Glenn
      http://www.runnel.com
