    Autofold bug
    8 Posts 4 Posters 380 Views 4 Watching
    • gillesG Offline
      gilles
      I notice a strange behavior with autofold:
      Any idea?
      Autofold_V6.skp
      • cottyC Offline
        cotty
        Reminds me of this...
        my SketchUp gallery
        • gillesG Offline
          gilles
          Yes, but I don't understand why half of the folding is good and not the other one.
          • mitcorbM Offline
            mitcorb
            Hi, gilles:
            I tried to replicate your example, and noticed when I used a bezier curve approximately in the shape you show, and then delete the large face "under" the curve, erect it 90d, I get a similar effect. It looks as if one half of the curve stays welded and one half is subdivided into two other curves and sort of duplicated. (Is Sketchup creating temporary subgroups as part of its operation, and then not making the final corrections?)
            I did another little exercise where I bisected the full curve and deleted everything but the half curve and the area "above" it, erected it then mirrored and mirrored again. This completed the surfaces. Of course, this is not what you want, but may be a viable solution.
            • gillesG Offline
              gilles
              That's exactly what I do to get good shape, just a makeshi(f)t. đź’š
                Auto-fold, or SketchUp even, isn't aware of what your shape looks like. It just performs a generic triangulation. That's why you need to guide it when it doesn't fold as you want it to.
                • gillesG Offline
                  gilles
                  As you ca see on the image the triangulation is far from correct.
                  • mitcorbM Offline
                    mitcorb
                    You know, if it split the curve into two connected curves, could it be that there is a deeper level of triangulation across the rectangular starting face, that happens to affect the curve? Maybe not.
