    Swapped components come in at reduced size
    5 Posts 4 Posters 213 Views 4 Watching
      MitchB
      I have a fairly large master plan scene with hundreds of trees. I decided to use instances of a small sphere to place in the locations I wanted these trees and used the replace instances feature to replace these with a model of a tree I had in the scene-yet they all come in at about half the size.
      When I go back to component tree I am using to replace the spheres and re-place it in the scene it is still as large as it originally was. The only thing I can think of is that the sphere I used for my placement was originally larger than the downsized version I used as place-markers but why would that affect the size of the component tree I am replacing these with?
      Can anyone suggest a solution for this issue?
      Thanks!
        Maybe component Dropper by Thomthom makes some help ?
          MitchB
          Very interesting, thanks for the reply. That tool looks handy but I see it warns that 2D objects will not work with it and my trees are such.
          On aside I have figured out that the downsizing of the original sphere component is what causes the trees to come in smaller. Obviously that history remains when the component is swapped-FYI for anyone having a similar issue.
          • pbacotP Offline
            If you scaled down your placeholder components after they were made, this scale factor will apply to the reloaded components.
            • cottyC Offline
              cotty
              Maybe GhostComp from Fredo6 will be helpful for such task?
              my SketchUp gallery
