Swapped components come in at reduced size
I have a fairly large master plan scene with hundreds of trees. I decided to use instances of a small sphere to place in the locations I wanted these trees and used the replace instances feature to replace these with a model of a tree I had in the scene-yet they all come in at about half the size.
When I go back to component tree I am using to replace the spheres and re-place it in the scene it is still as large as it originally was. The only thing I can think of is that the sphere I used for my placement was originally larger than the downsized version I used as place-markers but why would that affect the size of the component tree I am replacing these with?
Can anyone suggest a solution for this issue?
Maybe component Dropper by Thomthom makes some help ?
Very interesting, thanks for the reply. That tool looks handy but I see it warns that 2D objects will not work with it and my trees are such.
On aside I have figured out that the downsizing of the original sphere component is what causes the trees to come in smaller. Obviously that history remains when the component is swapped-FYI for anyone having a similar issue.
If you scaled down your placeholder components after they were made, this scale factor will apply to the reloaded components.
Maybe GhostComp from Fredo6 will be helpful for such task?
