    Hans Wegner, Oak sideboard + a little tutorial
    24 Posts 10 Posters 1.9k Views 10 Watching
    • massimoM
      massimo Moderator
      Just the model for now. πŸ˜„
      Since the joint between the curved legs and the flat parts took a bit of trials, I post also a little tutorial on how I did that (also a downloadable high-res version included). Hope it's useful. πŸ˜„
      P.S. I think the wicker texture still needs a bit of work.
      tutorial_finale_reduced.zip
      • Jean-FrancoJ
        Jean-Franco
        Hi Massimo,
        thank you for sharing your nice tutorial.
        The sideboard itself is an interesting piece of work.
        Do you intend to build it ?
        Jean-Franco
        • massimoM
          massimo Moderator
          You are welcome Jean. πŸ˜„
          The sideboard is really lovely as all Wegner's furnitures are. Full of subtleties.
          Well, I do not think. At most I might try some render. πŸ˜„
          • novenaN
            novena
            great modelling skills Massimo!!! and thanks a lot for sharing your tutorial...
            best
            V
            http://hdzarkitektur.wordpress.com/
              Curviloft or extrude edges can make miracles! β˜€
              • massimoM
                massimo Moderator
                Thanks Victor. πŸ˜„
                Indeed Pilou. πŸ˜„
                • alvisA
                  alvis
                  I am always for CurvyLoft, incredible tool, good tutorial. Thanks
                  • massimoM
                    massimo Moderator
                    You are welcome Alvydas, πŸ˜„
                    • olisheaO
                      olishea
                      nice little tutorial massimo πŸ‘
                      oli
                      • allanxA
                        allanx
                        I love the texturing on this one..thanks
                        allanx
                        Portfolio
                        • massimoM
                          massimo Moderator
                          Thanks again guys. πŸ˜„
                          • hellnbakH
                            hellnbak
                            Nice model, and nice method you came up with. I downloaded Curviloft a long time ago and haven't used it yet. Guess I should.
                            • massimoM
                              massimo Moderator
                              Guess I should.
                              Definitely. πŸ˜„
                              Just some quick shots with Thea testing the model & materials with a couple of spots and a HDRI very low in intensity. Also changed the wicker texture.
                              • DanielD
                                Daniel
                                Beautiful modeling. Thanks for the tutorial.
                                My avatar is an anachronism.
                                • l_breaultL
                                  l_breault
                                  Great model! That is a very nice wicker texture.
                                  Thanks,
                                  Leo Breault
                                  http://www.breaultdesignstudio.com
                                  • olisheaO
                                    olishea
                                    Great renders! Love the textured studio setup behind too. πŸ‘
                                    oli
                                    • massimoM
                                      massimo Moderator
                                      Thanks guys. πŸ˜„
                                      @Daniel, you are welcome.
                                      @Leo, was made seamless with Pixplant (it required a bit of work) starting from a photo and then edited in PS in order to add the stains, darker lines etc.
                                      @Oli, it's just a dark cardboard texture.
                                      I'm preparing some simple interiors with this sideboard. Lets see how come out. πŸ˜„
                                      • massimoM
                                        massimo Moderator
                                        A couple of shots in interiors.
                                        • hellnbakH
                                          hellnbak
                                          This just keeps looking better and better! Wonderful work
                                          • olisheaO
                                            olishea
                                            If you told me these were photos I would completely believe you! Killer images! Second is a touch noisy but I'll let you off πŸ˜„ πŸ‘
                                            oli
                                            • 1 / 2
