    Cannot draw soft edges
    5 Posts 4 Posters 426 Views 4 Watching
    • R
      rumcajs
      I did draw many soft edges, while I corrected rounded corners on object. Later suddenly the tool stopped working and it draws only hard edges, anywhere. I§d stress a lot with it, but nothing helped.
      http://i46.tinypic.com/288wq5e.png
      BTW: Did you change icons which are on post page. Why they are gray?
      • gillesG
        gilles
        Select the edge(s) then entity info / soften.
        • pbacotP
          OP is trying to use the Pen tool that draws soft edges.
          Rumcajs, Try posting in the thread for the plugin for best responses.
          • jgbJ
            jgb
            Or draw the line, then select the ERASER tool. With thumb holding down the <CTRL> key, click the eraser on the line. It will become soft and smooth.
            If you hold both <CTRL> and <Shift> keys, a smooth, soft or hidden line becomes hard.
            jgb
            • R
              rumcajs
              Thanks. This one was quite [highlight=#008000:39tvc7vr]helpful![/highlight:39tvc7vr]
